Changed transmission fluid, replace washers?
Old Mar 16, 2009 | 04:08 PM
Artesial's Avatar
Default Changed transmission fluid, replace washers?
I just changed my transmission and differential fluid this past weekend and I just noticed today the DIY guides say to replace the washers for the drain and fill bolts. Is this absolutely necessary? Will fluid leak from it unless you do this? I can always order them from hardtopguy.com but I just wanted to get input from you guys before I redo the whole thing again if nothing bad's going to happen.
Thanks.
Old Mar 16, 2009 | 04:21 PM
mlc's Avatar
mlc
You should be fine. Just take a look for leaks once and a while were you park the car.
Kevin
Old Mar 16, 2009 | 04:26 PM
Vanishing Point's Avatar
Check the plug areas, if it's dry your good to go. I would change the washers, it's cheap insurance of a proper seal. Check with some of our sponsors, the washers are cheap so buy several.
Old Mar 17, 2009 | 10:06 AM
INTJ's Avatar
It is not going to kill you, in a pinch I flip them over and reuse them just once. But for a couple of cents, just replace them next time.
Old Mar 17, 2009 | 11:21 AM
Saki GT's Avatar
Fwiw I typically change the washer every third change. No leaks yet with this rotation.
Old Mar 17, 2009 | 06:15 PM
Artric's Avatar
I think I MIGHT have changed my crush washer once on my Integra in 100k miles and never had a problem. I doubt anyone has suffered crush-washer-fail. Most do not change them.
Old Mar 17, 2009 | 09:10 PM
roadie114's Avatar
I wouldn't worry about it. I tried to find the washers, and my dealer was out of stock. Makes you wonder how they do a "proper" change of fluids there huh?
macr88
Drivetrain
Jan 20, 2011 04:34 PM
dan_uk
Feb 10, 2009 04:47 PM
vietdragontekx
Apr 9, 2008 03:24 PM
shouldibuy
Jan 20, 2008 09:30 PM
