is changing back brakes and rotors easy?
i wanted to change my stock rotors for slotted/drilled back and front. also pads. ive changed back brakes on my old integra and i needed a tool in order to compress the caliper when i took out / the old brakes. im not sure if s2k is the same thing. and if its easy to change rotors? thanks for your help also is drilled better than slotted or get the combination.
make sure for the rear brakes you dont just compress the piston back in. you need to rotate to compress. do NOT use a c clamp.
as far as for your rotor question. why are you even thinking slotted or drilled? if your looking for performance neither is going to benefit. if you just want some bling bling, then go for it.
The rear brake piston needs to be screwed in to retract it. You can use whatever you have handy that fits in the slots in the caliper, or you can a little cube thingy with prongs on it designed to go onto a ratchet and work on those slots.
and use a 3/8" racket with an extension to screw it back in. It will fit right in the center of the piston
