Changing Diff Fluid
Old Jul 21, 2004 | 05:23 PM
9krevz01's Avatar
Default Changing Diff Fluid
i hear like a whining noise coming from the rear when i turn to the left or the right, i just had my diff fluid changed but i was wondering if i could go to like a synthetic mobil fluid after i been using regular honda diff fluid. i heard in another forom people talking about this noise, but know one knew what it was .. thanks for your help
Old Jul 21, 2004 | 05:31 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Get some LE607 for the dif. Changing from the crap that's in there now to this stuff will do lots of good and no harm.
Old Jul 21, 2004 | 05:39 PM
9krevz01's Avatar
who makes an sells that i never heard of it
Old Jul 21, 2004 | 05:51 PM
KrazyKarim's Avatar
Check it out here in the s2ki markteplace http://marketplace.s2ki.com/s2ki/customer/...1&cat=24&page=1
Karim
Old Jul 22, 2004 | 05:22 AM
Squeezer's Avatar
uh oh, if you had your honda dealer change your diff fluid, and now you are hearing strange noises, I bet they put in the wrong diff fluid. i bet they put in the one made for the AWD CRV, and this fluid is not compatible with the s2000's differential. i would check your work order and see if it specifies what fluid they used or call them and ask.
do a search, several people have had the dealer replace the differential fluid and used the wrong fluid and toasted the differential.
Old Jul 22, 2004 | 11:00 AM
Ludedude's Avatar
Administrator
And get that stuff out of there asap if they did put the wrong fluid in there.
Old Jul 22, 2004 | 01:51 PM
9krevz01's Avatar
i asked them they told me they put gl 5 or something
Old Jul 22, 2004 | 02:34 PM
9krevz01's Avatar
i just bought the new stuff but gm sells an additive for diffs should i add this to it ?
Old Jul 22, 2004 | 02:41 PM
Ludedude's Avatar
Administrator
No, the Torsen diff in this car doesn't require friction modifiers like other clutch type LSDs sometimes benefit from.
Old Jul 22, 2004 | 03:18 PM
9krevz01's Avatar
ok so u think i should be all set with the le607 ?
