Changing Diff Fluid
Old Feb 20, 2009 | 02:04 PM
chrisjgiuliano's Avatar
Default Changing Diff Fluid
Hey Guys,
Changing the diff fluid. I looked at the DIY thread, but it only has part numbers and not sizes for the replacement gaskets (washers?) for the fill and drain bolts. I'd like to just go to home depot to get them rather than order online and wait and pay shipping. What sizes are these things? Part numbers are Replacement washers 90402-PCZ-003, 90401-PCZ-003
Thanks guys!!!
Old Feb 20, 2009 | 02:33 PM
99SH's Avatar
One of the washers is copper, dont think they sell that at home depot.
Why not go to your local honda dealer and purchase em?
Old Feb 20, 2009 | 02:36 PM
I called, they don't have the copper one. They have the drain washer but not the fill one. I was just seeing if I could get away with not having to wait on honda to order it.
Old Feb 21, 2009 | 09:50 AM
s2k aok's Avatar
i have a whole ton of washers, can't remember if i got them from hard top guy or handa, but when i did oil changes, or differential fluid changes i always forgot i had a stash and just used the old washers.
Old Feb 21, 2009 | 01:35 PM
terahertz's Avatar
the washers are the same size i think. i had been using the copper one on the drain, when finally the other day i looked to see where each part number went in the diagram and it turns out the copper one is for the fill bolt. both fit on both.
Old Feb 21, 2009 | 03:46 PM
Alphamale's Avatar
Maybe they changed for MY06 but I ran into this problem today. Changed the diff and put the fill washer on the drain bolt by mistake. I only noticed cause the drain washer will NOT fit over the fill bolt. Went to get some washers and the dealer told me they are back ordered until March...
Problem is the fill washer is now crushed against the drain bolt. Can not get it off without messing up the bolt. So I've got to watch for leaks and wait until March to get a new drain bolt and washer.
Old Feb 21, 2009 | 04:16 PM
terahertz's Avatar
hmm they should be the same... Btw mine got crushed too. Just put a flat screwdriver inbetween and twist. Do it in a couple places and it will come off.
Old Feb 21, 2009 | 04:49 PM
roadie114's Avatar
18mm I believe for the washers for both bolts. Bolt threads are the same size, just the bolt heads are different, at 23mm and 24mm. I just changed mine, and used aluminum for both that I found. My Honda dealer was out, so I just matched the correct size at a local auto store. In case you're looking for a 23mm open ended wrench for the fill bolt, I just found one at Kmart, Craftsman brand.
Old Feb 21, 2009 | 06:05 PM
Alphamale's Avatar
I guess I was too comfortable doing the job and didn't pay enough attention. It makes more sense they would be the same. This is the second time I've changed the diff. No problems the first. Oh well, this won't happen again!
Old Feb 21, 2009 | 08:11 PM
99SH's Avatar
If you need washers now go here: http://www.handa-accessories.com/s2000-04maint.html
XtC-604
Jan 22, 2010 08:59 PM
s2k bandit
Aug 20, 2009 08:53 PM
red 2000 s2k
Mar 26, 2009 11:11 AM
rijowysock
Aug 21, 2006 12:34 PM
Saab9-3
Apr 8, 2003 04:52 PM
