Changing diff oil
Old May 26, 2012 | 05:40 PM
F1 S2K's Avatar
Default Changing diff oil
No, I'm not about to ask "how do you change the diff fluid". I know how to use the "Search" button. However I wanted to share a little trick from today...
As we all know the clearance on the "fill" bolt is not exactly generous enough to fit a socket (even a shallow one) and the ratchet head. I've read the thread where folks get creative and cut the socket in order to find enough clearance. Well, here is another approach...
Next to socket is a socket cap. It fits like this along with a box end wrench:
Pretty nifty little device. They come in a set from Craftsman. Bag looks like this:
Sure - if you go through all this trouble why not use a 23mm wrench? Well they are kinda big and using the cap I used an 11/16 box-end, which is much easier to work with. At any rate - just another way to skin the cat.
Old May 26, 2012 | 08:04 PM
sillyboybmxer's Avatar
just bought a 23mm wrench today to do this tomorrow
Old May 26, 2012 | 08:17 PM
EriS2k's Avatar
nice trick!!! Thanks for sharing!!
what oil will you use??
Me - Mobil 75W90
Old May 26, 2012 | 08:18 PM
Homer Simpson's Avatar
thanks!
I used to use a adjustable wrench for it
Old May 27, 2012 | 05:31 AM
Jdrum1's Avatar
this is a great trick, but why use it over a wrench?
Old May 27, 2012 | 05:35 AM
F1 S2K's Avatar
I just wanted to show an alternative.
I prefer to use a socket over a wrench but that is a matter of personal taste.
Old May 27, 2012 | 06:08 AM
zeroptzero's Avatar
I've always wanted to get a torque wrench on the fill bolt but of course there is no room for that, thus I prefer to use the 23mm wrench, with it being a decent length I can get some decent torque to loosen and tighten the bolt, it seems to snug down nicely with the longer wrench. Your tool might work nicely without having to jack up the car which is cool, I have to jack up the car to use the 23mm wrench. Thanks for posting that info.
Old May 27, 2012 | 06:10 AM
S2KIrishman's Avatar
have my 23mm wrench sitting on the floor board of my car, actually
Old May 27, 2012 | 11:36 AM
my stupid drain/fill bolts were switched at some point in time and now i cant fricken do it because my tools i just bought are now backwards
Old May 27, 2012 | 12:32 PM
zeroptzero's Avatar
that sucks, time to buy a new wrench, then return it for refund if you buy it from a store that allows that. Walmart ?
