Changing fluids, how many washers.
Old Mar 31, 2007 | 03:54 PM
Fr3AkAzOiD's Avatar
Default Changing fluids, how many washers.
I'll be changing my fluids for the first time in a few days (oil, transmition, diff, clutch, brake). I have 2 14mm and 1 20mm crush washers.
Do I need more?
Thanks in advance for my nooby questions.
Old Apr 1, 2007 | 04:06 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
engine oil- 14mm
Trans- 14mm drain, 20 mm fill
dif- 18mm alum drain, 18mm copper fill
If the washers can be lifted off the plugs by hand, and they are not deformed, you can re-use them.
Old Apr 1, 2007 | 06:34 PM
tbaker's Avatar
Originally Posted by Billman250,Apr 1 2007, 07:06 AM
engine oil- 14mm
This is interesting because I just changed the diff and trans. fluid yesterday for the first time ever (since I have owned the car anyhow) The diff fill/drain plugs were huge. I want to say they took a 23mm socket.
Did they make different years different sizes?
Old Apr 1, 2007 | 06:36 PM
SenderGreen's Avatar
[QUOTE=tbaker,Apr 1 2007, 06:34 PM] This is interesting because I just changed the diff and trans. fluid yesterday for the first time ever (since I have owned the car anyhow)
Old Apr 2, 2007 | 02:13 AM
RACER's Avatar
[QUOTE=SenderGreen,Apr 1 2007, 07:36 PM]No I believe the fill/drain bolt sizes remain the same through all model years for all fluids.
Old Apr 2, 2007 | 05:36 AM
CoralDoc's Avatar
Here's an example of a deformed washer - it's the one on the left .
Old Apr 2, 2007 | 08:30 PM
Utah S2K's Avatar
I believe the sizes are th same for various MY's. The issue here is tat one person is giving the scket size of the plug while Billman is talking about the Inner Diameter of the hole on the washer.
Utah
Old Apr 2, 2007 | 09:38 PM
Utah
No one gave any socket sizes before his post
Also, that is what I said
What Billman250 was stating was the size of the crush washers for the fill/drain bolts.
Old Apr 2, 2007 | 10:37 PM
RACER's Avatar
This is correct. 18mm inner diameter on both bolt's, and 23 and 24mm bolt head's.
Pinchy
Aug 1, 2011 03:18 PM
littlealex
Apr 3, 2010 11:18 PM
s2k bandit
Aug 20, 2009 08:53 PM
UCrazyKid
Sep 4, 2004 11:57 AM
KryptoniK
Mar 31, 2002 03:47 PM
