Check engine flashes at startup
So every time i start my car up, the check engine light will flash 5-6 times and then disappear. it never comes on anytime else. what the heck is going on?
Originally Posted by Currahee474,Feb 6 2007, 03:30 PM
maint required slip of tongue. so its nothing to worry about i can just reset it?
Originally Posted by SS2000GT,Feb 6 2007, 05:25 PM
Don't worry, Zach. Just cut a piece of 1/4" x 1/4" electrical tape, and cover it up
As taken from Xviper's thread:
To reset the MAINTENANCE REQUIRED light (As indicated by the light that says, "MAINT REQU'D"):
- Have key inserted in ignition but in the OFF or LOCKED position.
- Push and hold the trip reset button on the right bottom corner of your gauge clutster.
- Turn key to full ON position and continue holding the button till the light goes off.
-(This part has been added for those who are impatient or who have the light only at the "blinking" stage and not yet solid.) KEEP HOLDING THE BUTTON FOR ABOUT 30 SECONDS TO BE SURE OF A POSITIVE RESET. Or maybe just be patient and wait till the light is on all the time before doing this.
- (Some manuals may be a bit off in that they do not tell you to turn the key to the ON position.)
beefystud
Oct 28, 2016 09:13 AM
You sure its the Check Engine? Or the Maint req'd?
