Check Engine light
Old Sep 15, 2006 | 09:24 AM
jdmfntc's Avatar
Default Check Engine light
i have a check engine light on in my 01 s2k i had my friend scan it and it said that my air pump sensor had a low air flow o low current. so i had it replaced and it went away for a few days and now its back on with the same code.. anyone out there have or heard of this problem or know how i can get rid of it?? Thanks.
Old Sep 27, 2006 | 09:01 AM
jdmfntc's Avatar
yes it is code P0411
thanks for the tip i will have to try that
Old Sep 27, 2006 | 04:18 PM
s2kboii's Avatar
aye bryan what if you routed all the vacumn lines correctly and check the check valve make sure it's in right position and the lights still on? what do i do then?
Old Sep 27, 2006 | 04:35 PM
darkfx's Avatar
buy a new airpump
Old Sep 27, 2006 | 10:30 PM
SenderGreen's Avatar
There is a TSB for S2000 00-05
06-055 (S2000) Airpump MIL Comes On With DTC P0410 P0411 P1410 P1415 P1416 orP2445.
It's not in the TSB section yet, someone posted it in the library a while ago and I snagged it.
EDIT: If anybody wants it let me know, I can email it.
EDIT: Theres still a link in the library if this one dosen't work
http://www.alldata.com/tsb/Honda/115562520...6-055/6055.html
Thanks twohoos.
Old Sep 28, 2006 | 07:38 AM
goldenfri's Avatar
Check to make sure your vac line are actually hooked to the air pump behind the bumper and what exactly did you have replaced?
bsk_760
Oct 16, 2011 11:38 PM
s2000_19
May 29, 2009 01:47 PM
sbrodacz
Sep 7, 2008 08:23 PM
dnme.s2k
Jan 27, 2007 03:41 AM
DannyInKorea
Feb 16, 2006 09:32 AM
