Check engine light
Old Mar 12, 2007 | 11:04 AM
a6s7d8's Avatar
Default Check engine light
Hi,
I was driving yesterday entering the freeway so i decided to gun it a bit. I went to around 8000 rpm in first and second gear. Around 60 - 65 mph i noticed the check engine light flash a few times then turn off. Can someone tell me please what this means? The check engine light is off now. It only flashed like 3 times or something like that. I have an 02 s2k incase you needed that info. If someone knows what this means please let me know.
Thanks, Al
Old Mar 12, 2007 | 11:40 AM
CoralDoc's Avatar
Unless you are a cyborg, the only way to find out is to have the code read. However, since there is no check engine light now, I don't know if a corrected code will still be readable.
Old Mar 12, 2007 | 05:54 PM
jeggy's Avatar
if it was the check engine light that was blinking, it would have stored that info in a snapshot. even if the light is not on right now. you'll have to use an engine scanner, not a code reader but a full on scanner that can bring up the stored info in your computer.
Old Mar 12, 2007 | 06:54 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You sure it wasn't the Maint Reqd light?
Old Mar 12, 2007 | 07:42 PM
Utah S2K's Avatar
1) Check all fluids-may have been a low level indicator.
2) If fluids are good then have the "Pending" codes pulled along with any "freeze frame" data.
If you get a code or "suspect" freeze frame data post here for advice. The codes can be pulled for free at most part stores (i.e. Autozone, PepBoys, Etc.).
Utah
P.S. Oh...and what he said
Old Mar 12, 2007 | 07:52 PM
gomarlins3's Avatar
That was going to be my question as well.
If you are sure it was the check engine light, pull the code.
Old Mar 12, 2007 | 08:19 PM
CoralDoc's Avatar
It's easy to check and see if it was the Maint Req light. Turn on the ignition and let us know if it is flashing now.
Old Mar 13, 2007 | 09:50 AM
a6s7d8's Avatar
Thanks for the replys guys. I will check the fluids and drop by autozone see if they can read any codes. I know it was the check engine light and not the maintance required light. I was really wierded out about it, stareing at it instead of the road :-D. Do you guys think a dirty air filter might cause this?
Al
Old Mar 13, 2007 | 10:27 AM
gomarlins3's Avatar
Al
Doubtful.
Old Mar 13, 2007 | 11:46 AM
hondamanwill's Avatar
If the light was flashing this means you have a miss fire. The light flashes cause it can cause damage to your cat. If this happen there should be freeze frame data.
beefystud
Oct 28, 2016 09:13 AM
Bobby_Digital
Sep 14, 2010 12:21 PM
jakejjang89
15
Mar 17, 2010 11:27 AM
Psicho54
Jan 24, 2007 09:40 AM
turbomadness
Feb 18, 2002 11:05 AM
