Check engine light in 95 Civic
Old Dec 19, 2001 | 07:38 AM
krazik's Avatar
Administrator
Default Check engine light in 95 Civic
My G/F's 95 Civic EX has been throwing up a check engine light. How can I find out what the code is?
And yes, I have checked the gas cap.
Old Dec 19, 2001 | 08:18 AM
Bobway's Avatar
The ECU has a light on it, and should be located under the carpet in the footwell of the passenger side. Pull the carpet back and there is an inspection hole to see the light. When you turn the key to the ign on position, the light will flash a number of times in sequence. If there is more than one code, it will flash one first followed by the second. like two blinks <pause> followed by five blinks <pause> then repeats, would be code 2 and 5.
Old Dec 19, 2001 | 08:04 PM
smyroad's Avatar
Then you've got to find someone with the definition of the codes. Does anyone know if the codes are consistent across the Honda product lines? Do you think the codes for my '88 integra would match the '95 civic codes?
Old Dec 20, 2001 | 04:38 AM
Bobway's Avatar
Just post um up. I can tell you what they are most likely. Honda typically has used the same codes though for all their models.
Old Dec 21, 2001 | 04:35 PM
Utah S2K's Avatar
[QUOTE]Originally posted by Bobway
[B]Just post um up.
Old Dec 22, 2001 | 06:35 PM
ScottyBallistic's Avatar
I know im new to the board just purchased my s2k today red/black,But i do own a 95 civic cp running 400hp on NOS.Your car is OBDI and uses a flashing code ,but it is not on the ECU.What you have to do is above the right side kick panel you will find a few harnesses not plugged into anything your are looking for a 2 pin plug .You then take a paperclip and make a U out of it and connect the 2 pins together .Turn your ignition on and your check engine light should flash the code.If you purchase a Chilton repair manual from any local parts store it will list the codes .Then you can use the manual to repair the car.It will also show you how the same 2 pin connector is used to change the timing.Hope this helps .
Old Dec 23, 2001 | 10:00 AM
Bobway's Avatar
I guess I am dated as pre-OBD then.
Krazik must have gotten it figured out by now though?
Old Dec 23, 2001 | 11:54 AM
krazik's Avatar
Administrator
Thanks for the help guys. Unfortunately I was not able to check it before I left to go to my parents in Sun Valley, ID for christmas.
When I return this will be one of the first things I take care of.
To top it off the car (civic) was broken into on Thursday so I have a broken passenger window to fix too The only took the stereo which was a 5+ year old middle of the line sony cd player, Not a huge loss, but shitty none-the-less.
So can either of you guys tell me if I can replace the passenger window myself?
Old Dec 24, 2001 | 03:41 PM
SilverSurfer's Avatar
[QUOTE]Originally posted by krazik
[B]Thanks for the help guys.
Old Dec 24, 2001 | 03:43 PM
krazik's Avatar
Administrator
Nope, in the UCSC parking lot on her last day of work.
jakejjang89
15
Mar 17, 2010 11:27 AM
rustah
Nov 18, 2008 07:36 PM
gt2690b
Jul 5, 2005 10:59 PM
DVSwetwilly
Feb 28, 2005 01:11 PM
sbarbera
Nov 10, 2000 03:17 PM
