Check Engine Light After Oil Change
Old May 15, 2016 | 04:38 PM
RumRunnerS2k's Avatar
Default Check Engine Light After Oil Change
Hey Guys,
I changed my oil today. To take out the filter, I unplugged (what I believe is) the VTEC Solenoid to make room for my hand to pull the filter out from the top.
I changed my oil as usual. When I started my car, I noticed my check engine light was on... Checked my engine and realized I forgot to plug in the VTEC Solenoid!
Now Im not sure if it did anything bad, as the car still runs like it did before. However, I feel like it may be making a ticking noise like if the TCT was going out. This ticking noise makes sense because the plug is right next to the TCT, so Im wondering if the plug has anything to do with the TCT. Im afraid to drive my car now, so hopefully someone can help! Maybe Im just making myself think there is a ticking noise because the plug was next to the TCT and Im honing in on that area too much. I replaced my TCT a month ago, so I know it was perfect before.
Here is an image of the plug
Old May 15, 2016 | 04:49 PM
Car Analogy's Avatar
Yes, thats the Vtec plug. I also remove mine to make room to remove filter.
No, its in no way way related to tct.
You arent the first to start car with this connector removed. I even drove my car with it unplugged to test something once. No ill effects.
I suspect you are just being hyper sensitive to noises since you are concerned something happened. These cars are more noisy than most.
When was last time you did a valve adjustment? That can cause more noise than normal. Of course, its also unrelated to tct or vtec. But maybe that noise was there for a while and only now are you noticing. Or maybe your engine is normal, and you are just being paranoid.
Sent from my SM-G920P using IB AutoGroup
Old May 15, 2016 | 06:22 PM
Thanks for the reply. I think I was hyper sensitive to noises. I replugged it in and unplugged the battery to reset the car. The check engine light went out and all of a sudden the car sounded normal lol. I think me and the car are back to normal
Old May 15, 2016 | 07:12 PM
Avionics86's Avatar
If you get a chance, watch Wheeler Dealers S2000 episode.They disassemble and test the Vtec Solenoid and explain how it works. Pretty cool
nickoces2k
Jun 2, 2015 01:16 PM
zeroptzero
Jul 18, 2012 05:38 PM
Dolemike
Jun 3, 2004 08:42 AM
Dolemike
May 13, 2004 08:37 PM
gontheg
Jul 1, 2002 09:38 AM
