check engine light..dammit!
Old Aug 20, 2008 | 08:02 PM
gudetime/s2k6's Avatar
Default check engine light..dammit!
One thing I hate about mods is the check ingine light turning on. 2 weeks after I installed a test pipe. Can this be erased by the dealer and will it stay off?
Old Aug 20, 2008 | 10:15 PM
Stealth_SUX_'s Avatar
go to autozone and do it urself with a scan tool.. Plus it may not be caused by ur mods so you definnatly want to check it out...
Old Aug 21, 2008 | 04:51 AM
hondaf1's Avatar
get a scan tool from Harbor Freight or ebay for $30 and clear the code yourself, and you'll have it to clear codes in the future.
i used one anti fouler on the O2 sensor and still get codes then i put two on and haven't gotten code for over 2k miles.
Old Aug 21, 2008 | 06:18 AM
xrapidx's Avatar
What should we search for on ebay? Excuse my ignoranc - I'd hate to order the wrong thing
Old Aug 21, 2008 | 06:20 AM
Enthralled's Avatar
Actually, I thought the CEL fix didn't work on the 06+ cars.
Old Aug 21, 2008 | 06:36 AM
hondaf1's Avatar
search for "obd2 code" or "obd2 scan"
since you have a newer car, you should get one that support CAN.
if you want to spend extra, get one that show live data.
i have the Innovate OT-1, so i can use Logworks3 to do data logging along with reading and clearing codes.
Old Aug 21, 2008 | 06:41 AM
xrapidx's Avatar
Great...thanks.
Old Aug 21, 2008 | 08:36 AM
leester01's Avatar
if you're talking about CEL fix on test pipes
Old Aug 21, 2008 | 09:25 AM
Stratocaster's Avatar
Not for 30. That one will not read CAN that is required by the 06. All 06+ need a higher $ scan tool.
Old Aug 21, 2008 | 11:09 AM
hondaf1's Avatar
you're right, all 06+ require CAN.
if you have a laptop, you can get a CAN compliant one for $25 shipped
http://cgi.ebay.com/ebaymotors/OBD2-ELM327...emZ180280109325
if you want a hand held one. you can bid on this one that starts at $30. i'm sure you'll win the auction at $30 since there are so many out there and no one is bidding on them. or you can find one that has buy now for $40 + shipping.
http://cgi.ebay.com/OBD-II-OBD2-CAN-BUS-Di...id=p3286.c0.m14
either way, you can get one that's fairly cheap. it's good to have if you plan to do future mods. i personally like the ones that show live data, or even log data.
