Check engine light help
Old Feb 24, 2012 | 04:11 PM
UNiT_xEr0's Avatar
Default Check engine light help
Ok so my s2k was running great until I did a valve adjustment. The car was reading misfire on cylinder 2. Checked the spark plugs and everything was good so we assumed it was the coil pack. Bought a new coil pack and this time the CEL on misfire on cylinder 2 disappeared as p1399 popped up. Did a compression test and it passed with flying colors. My buddy that did the valve adjustment rechecked the adjustment and he said this time it was all closed up. So he redid the valve adjustment and it worked again until today. So it lasted a day before it started doing it again. The car is a 04 with 69k miles. They think my valves are going bad. Any input? Wanna get my car on the road again as gas prices are skyrocketing and driving my e92 drinks gas like its water
Old Feb 24, 2012 | 04:20 PM
DFWs2k's Avatar
A leakdown should be done before just assuming valves are done for.
Sent using free Tapatalk - Android FTW
Old Feb 24, 2012 | 04:24 PM
UNiT_xEr0's Avatar
I heard on the ap1 they go bad. Not ap2
Old Feb 24, 2012 | 04:28 PM
DFWs2k's Avatar
Valves hardly ever go bad on any model s2000. Valve retainers have been known to let go on ap1s.
Old Feb 24, 2012 | 04:31 PM
UNiT_xEr0's Avatar
I should do a leakdown test next then. I just wanna fix it. Any other inputs?
Old Feb 26, 2012 | 11:08 AM
UNiT_xEr0's Avatar
so i asked my buddy to do a leakdown test and instead of doing that they did a compression test again and said it was horrible. they said i needed new valves and they suggest me get a new head.. any input on this? whats the price range on this?
Old Feb 26, 2012 | 11:21 AM
s2000maniac's Avatar
check your injectors, some could be clogged.
Old Feb 26, 2012 | 01:57 PM
UNiT_xEr0's Avatar
i'll pull that off next and check. i'm gonna look for a good shop here in socal and i'm going to take it there on wednesday and see what they say. i only had the car for a month and all this is happening after the valve adjusment
Old Feb 26, 2012 | 02:52 PM
ImagineIt's Avatar
you maybe hit the money line fuel cut off too many times =( its not a rocket ship. sucks sorry to hear that.
Old Feb 27, 2012 | 10:43 AM
UNiT_xEr0's Avatar
went to a reputable shop and they said its a really bad valve adjustment. He said my idle and everything is fine and the motor is fine. He said its just a bad valve adjust cause he can hear it not opening. I hope this is the case because i wanna spend less as i can
