Check engine light help
Old Mar 15, 2012 | 11:14 AM
AlexS2200's Avatar
From: 13851 A Better Way #11D, Garden Grove, CA 92843
Ok, here is the truth about this car. UNiT_xEr0 brought his car to my shop and explained it has misfire codes and after driving it I can feel it missing at high RPM intermittently. He has been to 6 different shops, paid hundreds in compression tests, leak down tests, coil packs, spark plugs prior to coming into my place.
Fact:
Compression test #s Cyl 1 - 220psi, 2 - 205psi, 3 - 210psi, 4 - 240psi.
Leak down test #s Cyl 1 - 8% leakage, 2 - 12%, 3 - 8%, 4 - 3%
So you ask WTF, why is this still missing? Car does not over heat what so ever. 6 others couldn't figure it out, but we could hear water bubbling noises in the motor when doing the leak down test. I confirmed it was the head gasket that was causing the misfire because while I did the leak down I took off the radiator cap and found the coolant bubbling from the air we were putting down the cylinder. The gasket was not completely blown to make the car over heat, but just enough to mist water into the combustion chamber and cause misfire. After we pulled off the head, it was very apparent the gasket was leaking water/coolant because the exhaust valves were all rusty red color.
The OP got a PM from a very reputable NY mechanic here on s2ki telling him to change out his RETAINERS to Ap2! WTF? LMOA! The car is a 2004 Ap2! This is what happens when you try to internet diagnose cars! JUST DON'T DO IT, cuz you're wrong. Hahaha WTF does retainers have to do with misfire or a head gasket!
Old Mar 15, 2012 | 02:27 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Definitely wasnt me. I have never claimed or told anyone that retainers can solve a misfire.
I have always stated broken retainers show no symptoms at all. Not even the slightest noise.
I also think whoever stated that should be called out. They are obviously incompetent.
Old Mar 15, 2012 | 02:35 PM
Billman250's Avatar
Top Answer: 1
Originally Posted by ImagineIt
you maybe hit the money line fuel cut off too many times =( its not a rocket ship. sucks sorry to hear that.
It is a rocketship
And hitting that money line fuel cut will do no harm at all.
klapamos
Aug 31, 2016 04:55 AM
skinsfn36
Sep 18, 2012 09:42 AM
shepherddog
Apr 26, 2007 11:59 AM
jrb
Aug 1, 2006 09:07 PM
