check engine light trouble
Old Mar 22, 2003 | 08:00 PM
joeyriveira's Avatar
Default check engine light trouble
put on test pipe now check engine light came on just removed back cat need to know how to remove annoying light.mahalo joey
Old Mar 24, 2003 | 02:19 PM
SoDakS2K's Avatar
Get an 02 sensor from these guys!
http://www.lakeeffectperformance.co...ons&product=428
Here's the instructions if it doesn't come with them.
They are all on the blue C-Connector; Unplug it and splice from the eng compartment going into the computer.
NOTE: ONLY CUT THE PIN NO. 15 WHT/RED (SHO2S) - O2 SIGNAL WIRE. THE OTHERS YOU CAN REMOVE THE PLASTIC COATING AND SOLIDER THE SIM WIRE TO THE ECU WIRE.
Here is the PIN number on the connector, The wire colors, (the designation that Honda calls the wire), and purpose of the wire.
PIN NO. 7 GRN/WHT (SG1) - NEGATIVE
PIN NO. 8 BLUE (CKPP) - RPM
PIN NO. 19 (VCC1) - POSITIVE
PIN NO. 27 (TPS) - THROTTLE POSITION SENSOR
(directions from jcarlton)
Old Mar 27, 2003 | 10:24 AM
yellowbanana's Avatar
I tried alot of things on removal of my CEL on my s2ooo using a test pipe. I tried using casper 02 simalator and tried welding an exstention on my test pipe were the 02 sensor gose in. Thinking that it might get less exaust reading. It don't work I went back with my stock cat. now my CEL if off. My next step is a high flow cat. Just telling you what I tried. Good Luck. let me know if you can do it??
Old Mar 27, 2003 | 10:35 AM
Gernby's Avatar
Former Sponsor
The Casper's simulator sucks ass. The simulator from Lake Effects Performance is supposed to work.
From what I understand, you will still need a working simulator with the high flow cat, or your CEL will still come on.
LonS2k
Sep 5, 2011 04:43 PM
radfox
Feb 23, 2007 08:23 AM
Cycloneranga
Aug 19, 2006 12:52 PM
Cycloneranga
Aug 19, 2006 12:03 PM
S2KEvolution
May 25, 2004 08:11 PM
