Check Fuel Cap Error
Old Mar 3, 2010 | 06:02 PM
liquid6's Avatar
Default Check Fuel Cap Error
I have read and heard of issues with the AP1 and the gas cap/check engine light. Well, today I got in the car after work and started it up..."Check Fuel Cap" was flashing on the display. The last time I put gas in the car was on Saturday afternoon. I have never had and issue like this before. The check engine light is not on either.
The car is a 2006 AP2 and I just rolled 28K miles today. Any help is greatly appreciated.
Old Mar 3, 2010 | 06:03 PM
Slows2k's Avatar
Make sure the cap is tight, and keep driving.
The PCM will continue to run EVAP tests. If the cap was left loose the warning will go away. If the car has another problem the CEL will come on.
Old Mar 3, 2010 | 06:32 PM
liquid6's Avatar
So what is the best practice for the fuel cap? It is ratcheted down 3 clicks.
Old Mar 3, 2010 | 06:34 PM
Slows2k's Avatar
That's all. If the car has a tether strap on the cap, make sure it isn't under the cap.
Old Mar 3, 2010 | 06:44 PM
liquid6's Avatar
Ok. I just thought it was odd that it took 3 days for this to trip. Thanks for the help.
Old Mar 3, 2010 | 06:49 PM
Slows2k's Avatar
If there is something really wrong the CEL will come on
Old Jun 9, 2011 | 04:01 AM
hatalu's Avatar
I have same issue, my 2008 CR does that bs~! I changed the new gas cap yesterday, it still gives me that message and throw me a freak CEL for Leak EVAP this morning~! Bring back to dealer for this issue this weekend~!
Old Aug 19, 2019 | 07:05 PM
Asadoorian's Avatar
I have a 2002 with 68k miles and the check engine light comes on periodically. The first time, I took it in to the Honda dealer and after the diagnosis fee, a new gas cap cost me $200. Since then, I purchased a $50 analyzer and can check and clear the code myself. I have finally figured out that every time the fuel level goes down to half a tank, the light comes on. I can clear the code and fill the tank, and no problem. Now, I have to figure out what triggers the error at half full fuel tank! Any ideas, other than keeping the tank full?
Old Aug 20, 2019 | 07:52 AM
Chuck S's Avatar
This may help. TSB affects all 2002 S2000 cars.
http://s2000.club/recalls/TSB%2004-002.pdf
https://www.hondapartsnow.com/genuin...=pd:3457633,16
-- Chuck
Old Aug 20, 2019 | 09:50 AM
mikeyds's Avatar
I find with the cheapy cap I got from Advance Auto I have to grip the outside of the cap get it fully tightened. Using the handle makes it "click" but the cap won't be tight and throws the cel. Takes about two drives to go away when it comes on for me.
