Chunky diff fluid
Old Nov 6, 2007 | 07:07 AM
  #71
scareyourpassenger's Avatar
Originally Posted by SpitfireS,Nov 5 2007, 11:34 PM
scareyourpassenger Posted on Nov 6 2007, 04:13 AM
scareyourpassenger Posted on Nov 6 2007, 04:48 AM
Yeah..
Honda should have designed a rear end capable of handeling about 80% extra power.
Nissan did with the r200. That diff is bullet proof. They use it in the 350z, skyline, 300z and other cars that had over double the power from what it was originally used in. Heck it might have been cheaper for them to use the r200. Less failures and gearing was already correct for the application.
J
Old Nov 6, 2007 | 12:09 PM
  #72
SpitfireS's Avatar
scareyourpassenger Posted on Nov 6 2007, 06:07 PM
... and gearing was already correct for the application.
On final drive ratio I agree!
4.10
What ratio is used in the Nissan diff?
It was mentioned by negcamber in the "Post Your Diff Failure" post that it's all about being smooth on the track, and that's where the S2000 was designed & made for (IMhO).
Even in the CR version the stock diff & ratio is used IIRC.
Strenghten the diff, and something else goes, because something else has to go.
If things never break, you've made them way to heavy
(something I've picked up in my RC model plane years)
Old Nov 6, 2007 | 12:21 PM
  #73
4.10
The nissan Came with 4.10 for most of the car and sometimes higher.
I like 4.10..It must be the supercharger The ap2 transmission makes more sense though. Lower the acceleration gears but keep the cruising gear so that the gas milage doesn't suffer.
I agree weight savings is good but I would rather have the diff hold up. I was on a road course not a drag strip so there was none of the jolting type abuse.
Nissan diff may weigh in at 15-20lbs more but I could lose that just in wheels.
J
Old Nov 6, 2007 | 01:41 PM
  #74
ShocK's Avatar
Originally Posted by SpitfireS,Nov 3 2007, 06:30 PM
ShocK Posted on Oct 28 2007, 03:15 AM
Did you use the "solid" no-crush distance collar or the OEM crush sleeve?
What was the pre-load on the pinion bearings?
(without the ring gear & LSD installed)
The OEM crush sleeve automaticly gets the proper lenght as it crushes while torqueing the lockingnut down (in small steps).
IMO the solid crush sleeve had to be shimmed to the correct lenght which gives the proper pre-load on the pinion bearings.
Was there a manual or installation instructions with the solid sleeve (if you used it.. that is)
ShocK Posted on Nov 3 2007, 09:37 PM
During decelaration the pinion is pulled into the ring.
Because of the hypoid gear design.
If that locking nut has moved it may introduce play.
Play where you don't want it.
animeS2K is right about the heat cycle and break-in miles.
You did that too?
During "advanced" break-in (I mean, after a while) and at operating temp it isn't so bad to every now & then step on it a little bit, but only once. a day or so.
Let the diff(oil) cool down afterwards, allthough once warm it doesn't realy cool down anymore with driving, not that much anyway.
Richmond changed the tooth design a little on the 4.57's to reduce noise.
They were called 4.57-R.
4.57 ring & pinion are 32:7, that never changed.
The 4.56's are a totally different gear set.
4.56 ring and pinion are 41:9
Closer to OEM tooth count (41:10).
Tooth shape and count are the reasons gears make noise IMO.
It creates harmonics, vibrations, resonances and sometimes they peak at certain revolutions.
When my 4.57-R's stop whining I'm getting worried....
Yep J's distance collar is a solid piece, you use different shim sizes to get proper bearing pre-load, this is where my mistake was. I have to tear it all back apart and re-shim the pinion. It is the same OEM specs though so once I get the right shim I should be ready to rock again. Just learning how to do all this so maybe I can start putting a few together locally whenever someone needs it.
Old Nov 28, 2007 | 03:57 PM
  #75
Blew up another diff. Ap2 this time and it has a nice hole out the rear case...
Old Nov 28, 2007 | 05:04 PM
  #76
ShocK's Avatar
Wow, get a hint dude, upgrade, obviously you have money to play with so just build one already lol
Old Nov 28, 2007 | 05:08 PM
  #77
ShocK's Avatar
My diff is still out of the car.... this sux.... I waited two weeks for another shim, but I only got one, and it was still too thick. So now I'm getting a whole set of shims from 3.91mm down to the minimum setting, hopefully. Coming from Japan, last time it only took 2 days so hopefully by Friday I'll have my shim and get the one I need... because it sux waiting for parts and not being able to drive my car! haha
Old Nov 28, 2007 | 05:55 PM
  #78
I am leaving the fi club. If it isn't the diff it will be something else. Honda obviously designed this car for stock power levels if that.
J
Old Nov 28, 2007 | 06:00 PM
  #79
S2KPUDDYDAD's Avatar
[QUOTE=ShocK,Nov 28 2007, 09:08 PM] My diff is still out of the car.... this sux.... I waited two weeks for another shim, but I only got one, and it was still too thick.
Old Nov 28, 2007 | 06:03 PM
  #80
animeS2K's Avatar
J
Seriously, if you want a LOT of power, it's going to break parts not designed for that much power.
Reinforce the diff, axles, driveshaft, clutch, pressure plate... Then the weak spot is the transmission... I guess it all depends on how serious you want to get and how much power you want to put down... and how you want to drive it.
