Clearing CEL code same as resetting ECU?
Old Feb 8, 2011 | 07:54 AM
TigerStyle's Avatar
Default Clearing CEL code same as resetting ECU?
I cleared a stored code last week and I was wondering is that equivalent to resetting the ECU. I was wondering if I should follow the proper procedures for the car to "learn again" by letting it idle for 5-6 mins after warming up.
Old Feb 8, 2011 | 09:39 PM
Chris_Lum's Avatar
Usually if it's a stored code, the CEL won't clear permanently until you fix the problem. If it's an intermittent code, it will go away until the problem triggers again.
Old Feb 9, 2011 | 12:08 AM
TigerStyle's Avatar
I fixed the problem as the shop that did my clutch swapped two vacuum hoses. After that, I just used an obd2 scanner and cleared the code. It hasn't come back on for over 250 miles.
Old Feb 9, 2011 | 05:09 AM
Reckon's Avatar
You shouldn't have to reset the ECU. The car will learn again on its own.
c32b
Mar 16, 2012 09:25 AM
macr88
Engine
Jan 21, 2010 11:04 AM
JMP
Apr 4, 2008 03:25 PM
sano.
Aug 16, 2006 04:04 PM
Venomous S
Jun 21, 2004 05:24 AM
