clicking clutch
Old Sep 24, 2002 | 08:55 PM
DJSang's Avatar
Default clicking clutch
I just started getting this clicking in my clutch pedal. It's when I first drive the car, and when it's in lower gears, mostly first and second. Right after I let go of clutch, point where there is no more pressure, the pedal kind of clicks. Anybody know why this is?
Old Sep 24, 2002 | 08:59 PM
xviper's Avatar
Possibly a release bearing. One other forum member has reported that he is getting this repaired at the dealer and another Calgary member has indicated that his is starting to make a noise too. One of our local members is a Honda mechanic and checked the car and has said that it is most likely a noisey release bearing but not a real concern till it makes a consistent noise. If yours is, you should go get it checked out. I believe it's a warranty thing.
Old Sep 11, 2003 | 07:49 PM
Austblue's Avatar
Is the release bearing and the throwout bearing the same thing? I had my clutch tsb done and since then my clutch clicks similar to how DJSang is describing it. I can be in reverse or 1st and moving slowly engage and disengage the clutch and it clicks. At first I thought that it must have been the problem with the diff needing to be re-torqued and staked but I definitely hear the noise coming from the front end.
BTW when I had the TSB carried out I didnt replace the throwout bearing or the press plate just the friction plate. Or was it the press plate and not the friction plate
Old Sep 11, 2003 | 09:37 PM
xviper's Avatar
[QUOTE]Originally posted by Austblue
[B]Is the release bearing and the throwout bearing the same thing? I had my clutch tsb done and since then my clutch clicks similar to how DJSang is describing it. I can be in reverse or 1st and moving slowly engage and disengage the clutch and it clicks. At first I thought that it must have been the problem with the diff needing to be re-torqued and staked but I definitely hear the noise coming from the front end.
S2Kaz06
Mar 20, 2012 11:56 PM
PStanger
Aug 8, 2009 02:22 PM
B.Money
Apr 18, 2007 10:38 AM
axiom
Aug 21, 2002 06:48 AM
liujhong
Jul 24, 2002 08:37 PM
