clicking noise comming from engine?
Old Apr 10, 2005 | 04:35 PM
JP_Silver_S2K's Avatar
Default clicking noise comming from engine?
As soon as i start my s2k, I can hear an immediate rattling noise comming from the engine, when i pop the hood and hear it, the sound is comming from the top portion of the engine where the intake manifold is ( i think) or the drivers side. anyone know what this could be?
Old Apr 10, 2005 | 05:17 PM
cpr518's Avatar
My car is doing the same thing. I think its the valves. It usually happens by over-revving or missing a gear.
Old Apr 10, 2005 | 05:41 PM
mine only happens as soon as i start it up or when its in idle, if a give it a lil rev it goes away
Old Apr 10, 2005 | 05:53 PM
S2kracka's Avatar
Lifter-tick possibly? What oil/filter are you using?
Old Apr 10, 2005 | 06:59 PM
Incubus's Avatar
The S2000's solid lifters are much louder than hydraulic lifters that are found on more common automobiles. That's probably all it is.
Old Apr 10, 2005 | 07:50 PM
evilbeatfarmer's Avatar
I also have a ticking sound and it's most noticable ~3000 rpm. After that the engine noise drowns it out. I hope it's normal.
Old Apr 10, 2005 | 09:20 PM
Wisconsin S2k's Avatar
most of you are probably hearing rattle from the heat shield. And as stated, our engine will make a ticking noise that is quite noticable even from the driver's seat at idle.
If you had damage from a mechanical over-rev, your engine would be doing a LOT more than ticking. lol
Old Apr 10, 2005 | 10:55 PM
hpark's Avatar
it's prolly normal.....does it only happen when the car is cold (after sitting for a while)?
Old Apr 11, 2005 | 06:01 AM
I don't mean to hi-jack this thread but mines there warm or cold.
Old Apr 11, 2005 | 06:52 AM
WarrenW's Avatar
I get a clanging noise from the time I start it up until it's been running a little while, I mean warmed up into the 3 bars. Even then it will sound clangy while revving up through the gears until about a mile or so then the clanging goes away. I just assumed that's a charastic of an all aluminium engine. Anyone else have this happening?
Warren
