clunking noise
sometime i hear this clunking noise getting into first. when i stop in neutral and then wait a minute or two and then go into first i hear a clunk. it happens from time to time. i was just wondering if this is normal? i have avoided the problem just by engine braking and keeping the car in gear coming to a stop.
This is normal, and it's your fault. When you're idle with the tranny out of gear and the clutch engaged, the front half of the tranny is spinning. When you disengage the clutch and toss it into first, you are causing the front end of the tranny to abruptly be forced to stop, which causes the clunk. To avoid this, wait a second or two after you disengage the clutch before putting the tranny into gear.
he means, when your about to go, instead of pushing the clutch in and putting the shifter into 1st right away, try it like this.
1. Push clutch pedal (disengage clutch)
2. wait 2 seconds
3. Put it into 1st.
I've experienced this same "phenomena" and the above method works fine. I sometimes even like to wait the 2 seconds, and then shift it into 2nd gear first and then back up to 1st gear
PS. Even if your waiting in neutral, if the clutch is engaged (pedal not depressed) liek the other poster mentioned, the tranny is still spinning.
2. wait 2 seconds
3. Put it into 1st.
Originally Posted by roflitzjinno,Sep 12 2008, 01:46 PM
oh okay. but sometimes it still happens even waiting in neutral for the whole length of the red light?
So if you do whats mentioned above:
2. wait 2 seconds
3. Put it into 1st.
the tranny is given time to come to a stop on it's own, and you won't get the clunk.
RL7
Mar 14, 2003 07:05 AM
