Cluster Emergency Brake Light
About a week ago the brake light on the cluster turned on and will not turn off. Brake fluid has been topped off and there is no continuity when testing the terminals on the side of the master cylinder reservoir. The parking brake switch under the console is functioning properly. All three brake lights are also working.
What could it be? I have an appointment to get the master cylinder replaced but I am questioning if that is the problem being that there is no continuity between the terminals on the side of the reservoir when filled to MAX. Is there anything else I can check before dropping a few hundred?
The car is meticulously maintained and is not daily driven. It has about 71,000 miles.
Next, you gotta ask why the fluid got so low. Is there a leak? Are the brake pads worn too thin?
Try adjusting your parking brake. Should be 9-13 clicks. This warning light is a very basic circuit. 2 inputs; reservoir level and e-brake. You already checked the lack of continuity so power can only be coming from one other place. You indicated the brake was ok but most likely only did the switch test from the connector to ground. Most likely an e-brake issue adjustment issue.
Remove center console and loosen the e brake nut in the rear console opening completely. Pump your brakes several toms to set the self adjustment. Raise rear of car and raise brake lever 1 click. Tighten adjusting nut with a friend turning the rear wheel until the brakes just start to drag. Release lever and verify wheels no longer drag when turned. Lower car and pull brake lever. It should be 9-13 clicks. If that doesn't work you need to access the caliper, screw in the piston "+" , align the tits on the pads to the slots and repeat the adjustment.
Utah
Utah
