clutch acceleration
Old Feb 19, 2013 | 10:08 PM
znull's Avatar
Default clutch acceleration
hi,
my honda since last night has some issues sticking clutch pedal and some weird sound when i pressed it, and i cannot go forward with more than 30-40 km per hour and it goes up to 7000 RPM in gear 1,2,3, any ideea what is wrong? i had to call towing guys
thanks
Old Feb 19, 2013 | 10:47 PM
Duyx817's Avatar
clutch sleeping?
Old Feb 20, 2013 | 05:05 AM
pmptx's Avatar
That sounds like the typical test for needing to determine clutch replacement (motor accelerates but vehicle does not).
If you do a search you should find that exact scenario.
time for new clutch internals.
Old Feb 20, 2013 | 09:04 AM
MBHs2k's Avatar
Like others have already said, sounds like your clutch is starting to slip.
Old Feb 20, 2013 | 10:52 AM
Reckon's Avatar
To be sure, double check your clutch master cylinder and slave for leaks. If they look ok, and if the clutch fluid looks ok, then more than likely it's time for a new clutch. But check the little things first before ruling everything out.
Good luck.
Old Feb 20, 2013 | 11:17 AM
znull's Avatar
HI,
from what i saw near the clutch pedal something leaks i've already order the clutch kit (Tegiwa imports uk)+ master cylinder and slave cylinder will come soon from ebay too( didn't had time yet to order it )
Old Feb 20, 2013 | 12:52 PM
4forall's Avatar
A leak would not make your clutch slip, unless the fluid was pouring directly onto your disc/flywheel.
It sounds like your pressure plate/friction disc are worn out and need replacing.
Old Feb 20, 2013 | 02:24 PM
znull's Avatar
clutch kit and master cylinder were shipped today do i need to change the slave too? can anybody point me to from where should i get it? ebay should be ok? thanks im in europe.
Old Feb 20, 2013 | 07:39 PM
SLWASFK's Avatar
Always, on any car, replace the master and slave together. If you replace only one, the other will fail. Most likely within the year.
Old Feb 24, 2013 | 05:01 AM
znull's Avatar
anyone knows from where i could buy the slave cylinder clutch and ships to europe? i've tried talking with the buy on ebay (http://tinyurl.com/bc67fau) but said it does not fit my s2000 from 2000.. is that true?
thank you very much
mezzfin
Nov 11, 2010 02:51 PM
Pezza
Nov 27, 2007 10:15 PM
s2kbtos
Aug 11, 2007 07:46 PM
blacks2k
20
Mar 6, 2007 08:44 PM
REVZ TO9
Oct 4, 2006 09:01 AM
