clutch adjustment question
Old Oct 15, 2005 | 08:42 PM
03s2kman's Avatar
Default clutch adjustment question
can anybody tell me if its ok to change the clutch freeplay by adjusting the part where if you look up by the clutch, the clutch is resting on a small piece of black rubber which is attached at the end of a bolt?? i tried adjusting the clutch engagement but it doesnt really help with the freeplay. then i tried to adjust the other part i was asking about and it got rid of all clutch freeplay.
thanks ,
Steven
Old Oct 16, 2005 | 02:04 AM
03s2kman's Avatar
anybody please?
Old Oct 17, 2005 | 06:54 AM
apex2k's Avatar
Billman250 is the one you want to be asking,he is generous with his knowledge. You can try to PM him.
Old Oct 17, 2005 | 08:30 AM
CoralDoc's Avatar
It's not clear from your description, but free play is not adjusted where the linkage enters the bellhousing.
In order for your clutch to operate properly, you must have at least 1/2" of free play in the pedal. If you have adjusted all of the free play out of the system, you risk burning the clutch since it will not fully engage.
Old Oct 17, 2005 | 12:55 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
This is the most commonly misunderstood system.
There is only one correct setting.
If you push on the clutch pedal lightly with your finger, while looking under the dash at the back of the master, you'll see two different "freeplays". One is play between the rod and the master. This should be removed. Crack the nut loose with a 12mm open end, and take out the play by turning the rod with your fingers. Then tighen the locknut.
The other is the built-in freeplay in the master (the 1/2" or so Coral Doc is talking about), in which you'll see play in the piston itself moving in and out a little. This is normal, and should NOT be removed.
Old Oct 18, 2005 | 07:56 PM
03s2kman's Avatar
thanks for the info
Old Aug 24, 2007 | 12:17 PM
Saki GT's Avatar
Hey Billman, for visual reference, the bolt we should adjust is number?
Old Aug 24, 2007 | 02:08 PM
CoralDoc's Avatar
Items 1 & 2 in your photo allow adjustment of the clutch interlock switch that prevent the starting of the car unless the clutch pedal is depressed. The rod that enters the clutch master cylinder that Billman is talking about is 3. I've never adjusted it, so I cannot advise you further.
Old Aug 24, 2007 | 02:15 PM
Billman250's Avatar
Top Answer: 1
The nut number 3 is pointing to is correct.
Old Aug 24, 2007 | 03:34 PM
Slows2k's Avatar
Don't get stupid with the pushrod trying to make the clutch release point lower. You'll kill the clutch disc from it slipping all the time.
