Clutch alignment
Old Apr 5, 2010 | 07:00 PM
Haulin' S's Avatar
Thumbs up Clutch alignment
Ok, I need someone to help me with alignment. I want to make sure I get it right.
The tool I have feels a bit sloppy in there, and I don't know how to get the throwout bearing to align perfect the way it sits in there.
Can someone with more experiance than I give me some advice and some pointers?
Thanks!!
Old Apr 5, 2010 | 07:11 PM
96-EJ6's Avatar
Does you alignment tool have the little metal collar where it goes in the pilot bearing? If not, get one that does. If it does, just keep it centered by hand while snugging the first few pressure plate bolts. After that the disc will be clamped by the pressure plate and won't move. As for the release bearing, don't worry about keeping it centered, just dont let it fall in to the pressure plate. Once you install the gearbox the bearing will slip over the snout of the input shaft and basically align itself. Just slip the release fork onto the bearing and give it a good tug to lock it in place.
Old Apr 5, 2010 | 07:48 PM
Jano's Avatar
Agreed.
The throwout is not going to be your problem. If you test fitted the disk over the tranny splines you know how precise the alignment of the teeth need to be. If it's off even a couple mm the shaft of the tranny will just ram into the spline area of the disk and you won't be able to slide the tranny in that last 3/4". I did it without the tool but if I had to do it again I'd get the tool. If you can get your head in there you can do a visual inspection to see if it lines up.
When you slide the tranny in place, if it doesn't go in after just a little "encouragement", as much as you'll want to cry, pull it back and check the alignment. When it's right, it will slide right in.
Old Apr 5, 2010 | 08:14 PM
Haulin' S's Avatar
So noted. I think I know what I'm looking for now! thanks for your help, folks. I'll keep you posted.
Old Apr 5, 2010 | 08:49 PM
Mrfixit687's Avatar
Tip: If you're installing the tranny until the last 3/4" bit of space left between the tranny case and engine and it just doesnt want to go in, install the clutch fork in its installed position, have someone with a pry bar pry on it to release the pressure while you wiggle/push the tranny in, it'll align it self and slip in.
Old Apr 5, 2010 | 08:55 PM
Haulin' S's Avatar
Interesting concept. Putting it on the jack now. Just about to go up with it.
In case you're all wondering... I have a PC in the garage, too. That's how I keep posting so fast while working!
Lmao...
Old Apr 5, 2010 | 09:30 PM
Haulin' S's Avatar
Like a GLOVE!!! All by my lonesome, too. SUPER smooth. All about the right angle and the right amount of grease in the right places!
Old Apr 5, 2010 | 10:02 PM
Haulin' S's Avatar
By the way... You guys all ROCK! I don't think I could get half the stuff done on this car that I do by using all of your assistance and guidance for even HALF the cost it would take me to get it done at a shop. You are all a TREMENDOUS help and I sure appreciate it.
Old Apr 5, 2010 | 10:44 PM
Mrfixit687's Avatar
What clutch did you put in? It looks stock?
Old Apr 6, 2010 | 11:53 AM
Haulin' S's Avatar
It's an Exedy OEM replacement. The last time I used an F1 racing Stage 2, 6-puck, and I hated it.
hypforlife32
Sep 21, 2011 08:52 AM
r_duff
Mar 28, 2006 10:28 AM
r_duff
Nov 23, 2005 05:37 PM
jerrypeterson
23
Nov 28, 2004 12:02 AM
SwansS2K
Mar 15, 2004 02:37 PM
