Clutch Fluid Change
Of course there is the true story of a guy flying (I want to say it was a Cessna Skylane) his plane when he experienced a hydraulic fluid loss (not sure why) so he urinated in the system to get the landing gear down. It worked.
I mean... in a pinch, fluids are more or less incompressible... if you can work the bubbles out, and don't need to worry about lubrication, boiling over, etc, it can work.
He must have a very big...
Thanks Billman,
I tried this tonight, drove the car about 10 miles and checked the fluid, it looked pretty clean.
Parts stores were closed so i went to WalMart and the only kind they had was SuperTech DOT 3,
figured that was good enough because i was going to change a few times as the fluid is original.
I have a 2002 S-2000 with 34800 miles on it.
I will get the Honda DOT 3 tomorrow and change it again.
