Clutch help
Old Mar 5, 2013 | 05:13 AM
BenWise04's Avatar
Default Clutch help
Hello everyone I recently just got my s back on the road after 6 months of sitting in the garage and I've noticed my clutch is really soft up top and catches close to the floor and sometime I have to pump the clutch multiple times for Otto go into gear. I tried adjusting the pedal but it didn't seem to help much at all. Anything else I should try? Or any idea what is causing this?
Old Mar 5, 2013 | 05:36 AM
TopGear's Avatar
Are you low on clutch fluid? Either way, I bet you have air in the clutch lines.
You should always bleed the clutch thoroughly before adjusting the pedal. There's a DIY somewhere on the site if you're unsure of how to do it.
Old Mar 5, 2013 | 09:15 AM
BenWise04's Avatar
I've searched for the DIY and can't seem to find it
Old Mar 5, 2013 | 10:54 AM
realblag's Avatar
http://www.google.com/#hl=en&sclient...w=1920&bih=946
Old Mar 6, 2013 | 06:44 AM
BenWise04's Avatar
Thanks you so much ill do it when I get home and let you know how it goes!
Old Mar 6, 2013 | 09:13 PM
Simplegreenvr6's Avatar
Had this issue a few weeks ago...clutch fluid was nasty. Do a bleed and it should cure the issue. Also peak behind the pedal and see if you're getting a leak from the mc. New fluid should fix this leak.
Old Mar 8, 2013 | 01:55 PM
BenWise04's Avatar
Did the gravity bleed today clutch feels so much better thanks everyone for the help!
Acethriller
Nov 21, 2014 01:28 AM
stakss2k
Apr 15, 2014 10:04 AM
rikhemi
Sep 10, 2007 06:29 PM
osu s2k
Apr 16, 2004 07:51 PM
tothemaxx
Aug 17, 2003 04:35 AM
