Clutch issue
Old Mar 16, 2009 | 11:07 AM
terrors75's Avatar
Is the rod arm part of a new slave cyclinder or do I have to get a new one? The link mlc gave me for the rough clutch fix sounds a lot like the problem I have. So do I need a new rod or does it come with a new one when I buy the slave cyclinder?
Thanks for all your help guys.
Old Mar 16, 2009 | 11:18 AM
Tjs S2k's Avatar
You get everything, The whole cylinder + Rod arm when you get a new CMC. Pretty simple install also.
Old Mar 16, 2009 | 12:14 PM
my2ks2k's Avatar
part of the reason the clutch can feel rough/sticky is because it should look like this:
and after some time and wear and tear it looks like this:
check out this excellent thread for more info
Old Mar 16, 2009 | 01:19 PM
ahrmike's Avatar
^I did that fix. it helped.
I also changed my MC, changed TF, and now my clutch is happy, but worn down...(OEM, maybe? 60K miles.. )
Old Mar 16, 2009 | 01:45 PM
mlc's Avatar
mlc
Just make sure that you grease that well even if it is new. I think most of the problem with it was becuase they didn't grease it well enough at the factory.
Kevin
Old Mar 16, 2009 | 03:37 PM
skeithr's Avatar
try bleeding fluid first, i had same symptoms and thats all it took, 3 dollar bottle of brake fluid and a little of your time and whoevers willing to pump the pedal
Old Mar 17, 2009 | 04:06 AM
terrors75's Avatar
I bleed the cyclinder yesterday at the mechanics, now I'm waiting for the the MC and SC. I guess I'll try grinding down the ball arm.
Does any one have a pic of how the Dremel drill bite for the smoother looks like?
Old Mar 17, 2009 | 06:31 AM
terrors75's Avatar
When the engine is off the shifter goes in with no problem. If the ball arm is rough shouldn't it also happen when the engine is off too?
SamySnead
Jun 3, 2015 03:44 PM
crisskro
Nov 12, 2013 06:46 AM
Killin9's
Jun 6, 2011 04:21 PM
EssToOfouzEn
Feb 25, 2011 04:04 PM
jin6
Oct 13, 2005 06:31 AM
