Clutch line or Slave?
Old May 13, 2013 | 02:13 AM
AZ-S2000's Avatar
Default Clutch line or Slave?
Noticed the clutch line had a drip yesterday, this morning went to start the car and foot went down, had barely any resistance at the very bottom. Reservoir was empty. So clutch line (my bet) or slave? happy Monday!
Old May 13, 2013 | 05:28 AM
cdelena's Avatar
I have seen leaks from the master and slave at times but the lines typically don't fail unless damaged. Refill, bleed, clean and watch for any leaks.
Old May 13, 2013 | 10:21 AM
Car Analogy's Avatar
Its probably leaking from a seal, and dripping down onto the line to a low spot, so it only looks like its line leaking.
When MC leaks, it drips onto your feet. If its leaking from a line under car, most likely slave seal leak.
But check obvious, line connection fittings not tight.
Old May 14, 2013 | 02:56 PM
AZ-S2000's Avatar
I checked it, the line looks a little torn. Anyway to test a slave?
jayR2002
Aug 20, 2019 07:21 PM
03S2
Feb 20, 2011 02:17 PM
Edberg
Jan 19, 2010 10:40 AM
Suzukuh
Dec 3, 2007 01:47 PM
jackalope
Sep 28, 2006 12:53 PM
