clutch master cylinder ?
I was at a complete stop then went into first gear and started rolling when I went into first I heard a funny noise so I dropped it into 2nd and my clutch fell all the way down to the ground then I picked it up with my foot and tried to step on the clutch again but the peddle is stuck at the top where it normally sits and doesnt go back down like if theres heavy pressure on the clutch now (I was about 1 mile away from my house and drove it slow in 2nd gear till I got home) , I went under and looked at the clutch master cylinder and theres some grease/oil in there now as it shows on the top pictures , I plan on changing the CMC but any other advice I should look into ?
Change your Master and cylinder at the same time, check your fork if its not broken
Once your master starts leaking it will have a grease like mud right where rod goes in into master. Check for oil there, if its black oil spot your master is done, when master goes out your peddal changed pressure it might be soft one moment then normal the other.
If everything is fine bleed the clutch and hope you didn't brake anything is the clutch housing,
