clutch pedal
If you're talking about just the pedal assembly itself, you'll want to lubricate the hinge and the telescoping shaft that is pushed into the firewall when the pedal is depressed.
You also want to lubricate the actuator on the slave cylinder and where it makes contact with the clutch fork. You'll also want to lubricate where the clutchfork pivots, and if your transmission is out of the car, you'll want to lubricate the inner circumferential cavity in the throwout bearing and the splines.
