clutch pedal
Old Oct 7, 2008 | 09:59 PM
albe's Avatar
Default clutch pedal
hey i was wondering where do i lube/grease the clutch pedal at?
Thanks
Old Oct 8, 2008 | 03:21 PM
vwpiloto's Avatar
If you're talking about just the pedal assembly itself, you'll want to lubricate the hinge and the telescoping shaft that is pushed into the firewall when the pedal is depressed.
You also want to lubricate the actuator on the slave cylinder and where it makes contact with the clutch fork. You'll also want to lubricate where the clutchfork pivots, and if your transmission is out of the car, you'll want to lubricate the inner circumferential cavity in the throwout bearing and the splines.
Old Oct 8, 2008 | 08:25 PM
albe's Avatar
can i use mobil 1 grease on it?
Old Oct 9, 2008 | 05:06 PM
vwpiloto's Avatar
I'd use the Honda High Temp Grease (Urea Grease). You should be able to buy it at your local Honda dealer.
jfw432
Jan 13, 2007 03:59 PM
bs-inc.s2k
Sep 27, 2005 07:55 AM
XLeezardx
Aug 26, 2005 04:36 PM
WRS2K
May 12, 2001 06:01 PM
