Clutch pedal construction
Old Aug 2, 2005 | 06:55 AM
mikecorpen's Avatar
Default Clutch pedal construction
I want to extend my clutch pedal an inch or two so I can drive with the seat comfortably back. On my Miata, I used a clutch Pedal-mate (http://www.creativecontrolsinc.com/...nders/index.htm) with great success. When I went to install the unit on my '05 S2K, I discovered 2 cylindrical metal "bumps" (for lack of a better term...) on the back side of the clutch pedal. Anyone know what these are, and if they are likely to be damaged if they are sandwiched between the bolted-together parts of the extender? A site search produced only SIIK2NR's tongue-in-cheek alternative to the extender -- a strapped-on wooden block... Thanks for any help.
Old Aug 2, 2005 | 08:08 AM
xviper's Avatar
Hehe, I like the "child's tricycle, wood block" mod.
I think those "bumps" on the back side may have something to do with acting as a contact point for the pedal at its extreme travel. Anything you bolt onto the pedal should not alter this "stop point" or the pedal will not be able to be fully depressed. There are some examples of people who have installed aftermarket (read "fancy") pedal pads onto this clutch. They are not quite the "sandwich" idea you have in mind, but it seems to me that this can be done. Just ensure you take note of my previous caution about the stop point.
Old Aug 2, 2005 | 08:40 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Anything that restricts the full travel of the clutch will ruin the transmission. I've had customers that used a stopper on the backside of the pedal, so it just goes past the dis-engagement point.
Now their trannys are junk. One won't shift at all, the other grinds 1, 3, and 5.
I can't see your link, so I'm not sure what you intend to do.
Old Aug 2, 2005 | 10:20 AM
xviper's Avatar
Here, this one might work:
http://www.creativecontrolsinc.com/p...ders/index.htm
Old Aug 2, 2005 | 12:51 PM
Billman250's Avatar
Top Answer: 1
Thank you sir
That product should work well, just be sure the clutch pedal still hits the rubber bump stop on the firewall.
Old Aug 3, 2005 | 07:44 AM
mikecorpen's Avatar
Thanks, xviper and billman. I'll try to fit it this weekend, keeping your suggestions in mind.
Old Aug 3, 2005 | 12:05 PM
mikecorpen's Avatar
Got it fitted this afternoon. Only the flat part of the pedal is sandwiched, not the "bumps". The pedal arm still reaches the bumper on the firewall. Had a successful short road test. I can now put the seat a bit further back so my right leg isn't cocked, and arms can be extended to achieve something like what used to be called the "Italian" style of driving... The further-back seat position also lets me enter without always bumping my head on the top. Thanks again for the advice.
F1TwoThousand
Oct 15, 2018 04:01 AM
SDgoods
Mar 17, 2012 08:46 PM
nemesis2k
Oct 31, 2010 08:10 PM
Defender
Oct 14, 2002 06:26 AM
