Clutch pedal feels stiff
Old Oct 10, 2007 | 11:29 AM
modifry's Avatar
Honorary Member
^ I have tools, and some of them I know how to use!
Old Oct 10, 2007 | 01:52 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Originally Posted by pyrocpu,Oct 10 2007, 10:13 AM
Billman--Sometimes, a stuck clutch pedal, or one that doesn't/reluctant to return, can be the sign of air in the hydraulic line. It's happened to me before.
Yes, major air in the line can cause the pedal to NOT return on it's own.
This is a different problem. The pedal will always return on it's own. This problem feels like the clutch pedal is getting stuck on something when releasing from the floor.
Old Oct 11, 2007 | 07:47 AM
pyrocpu's Avatar
OHHHH! OK. Looks like I was talking about something else... my bad!
Old Oct 11, 2007 | 09:46 AM
SpitfireS's Avatar
There allready are 2 excellent posts about sticky and rough clutches.
Both with pics and lots of info.
https://www.s2ki.com/forums/index.php?showt...y+clutch+dbzerk
https://www.s2ki.com/forums/index.php?showt...h%20dbzerk&st=0
Both should be in the FAQ.
IMHO.
Very Honest
Old Aug 23, 2008 | 01:04 PM
slates74's Avatar
Whoa here's my problem! I also had my clutch replaced, suffered the same symptoms. When I pulled the slave cylinder to check if the mechanic had put UREA grease on it I saw that there was none and also noticed the nipple, but I thought it was supposed there. So I lubed and reassembled and suffered all the same issues again. If I replace the slave or grind the tip down will this help?
Old Sep 21, 2008 | 08:26 AM
Apex_AP1's Avatar
I have the same problem, but my oem clutch was replaced last year with another one. So Im sure it doesnt need to be replaced again. I dont launch and drive hard. So it must be a fluid/grease thing for me
Old Apr 25, 2012 | 02:15 PM
tone.101's Avatar
i seem to be having problems relating to something similar to this. When I press the clutch pedal, I don't feel any resistance at all. I also can't shift into gears. Could it be that it's not getting enough air in the hydraulic line as suggested above? Any info will help greatly, thanks.
Old Apr 25, 2012 | 02:51 PM
stupkid's Avatar
Check your reservoir
Also there shouldn't be air in the lines at all.
Sent from my iPhone using Tapatalk
s2kbtos
Aug 11, 2007 07:46 PM
jfw432
Jan 13, 2007 03:59 PM
vteconly
Sep 1, 2006 10:02 AM
XLeezardx
Jul 18, 2005 01:59 PM
sanee515
Aug 23, 2004 01:51 PM
