Clutch pedal goes straight to floor
Old Dec 22, 2011 | 08:28 PM
S_cav's Avatar
Default Clutch pedal goes straight to floor
I was on my way home from the gym and I am coasting in my car in neutral going about 4 mph. I push in the clutch pedal and I hear a pop and my clutch goes straight to the floor and stays there. I lifted the clutch pedal up with my toe and push it down again. There was no resistance, the pedal went straight to the floor again. When my clutch is resting on the floor it is impossible to put the car into gear because the pedal is not engaging anything. I checked the fluid levels and it was completely full. I have had my master and slave cylinder replaced a month ago by the Honda dealer in Tampa.
Any I ideas what is wrong with my baby?
Old Dec 23, 2011 | 04:09 AM
slalom44's Avatar
Top Answer: 1
My guess is that your throwout bearing fell apart. On the S2K the T/O bearing "pulls" the clutch open. You should start by removing the slave cylinder and see if your clutch fork is engaging.
Old Dec 23, 2011 | 06:42 AM
cdelena's Avatar
Happened to me on the back straight of TWS some years ago... the Honda dealership had failed to tighten the bolts holding the slave cylinder and it just dropped off and was swinging from the hydraulic line.
You have to know whatever this is it is a result of the work just done.
Old Dec 23, 2011 | 06:44 AM
FuknS2K's Avatar
read the entire post.. oops...
Old Dec 23, 2011 | 06:58 PM
S_cav's Avatar
The dealership replaced the slave cylinder for free because some of the seals exploded. So they say.
Old Dec 23, 2011 | 11:20 PM
AZ-S2000's Avatar
Easy way to check if its your slave is unbolt and press the clutch. You would also see your clutch for, but not sure if you can see the T/O Bearing.
StrokerSi
Aug 10, 2017 06:26 AM
tngay510
May 10, 2010 05:33 PM
Tneltn
Dec 14, 2008 12:06 PM
rikhemi
Sep 10, 2007 06:29 PM
airsport
Nov 5, 2003 05:23 AM
