crower cams tech question
im about to pull the trigger on some crower cams for my ap1 but instead of getting springs and TI retainers im thinking of doing it on a budget and just opting out to all ap2 hardware, my only concern is do the ap2 springs have enough tolerance to be spun up like you would in your average ap1 without valve float since in their original motor they only see 8k......
before anyone makes a smart remark about me being cheap or whatever, im planing a wedding and i need a little escape from the maddness and this is it and i can only afford to spend "X" amount right now for a loong while
if youre going to go through all that trouble to change the springs and retainers and cams, you should just buy supertech 95lb springs. they cost like 300 for the spring and ti retainers which isnt so bad. i bet the install will cost more. and if you do it yourself then itll come out the be the same
umair
Apr 23, 2015 06:23 AM
Fyrestrike
Oct 18, 2009 05:22 PM
