Clutch Pedal hit floor
Hi,
I have an 04 S2K with 26K on it. (daily driver, 3 miles to work). The car was not used recently for 2 weeks and when I got back in last week the clutch pedal was lower/softer than normal. Today upon starting it to go to work the pedal hit the floor and I could not shift into 1st to get out of the garage (good excuse to ride the bike).
Clutch fluid resevoir was almost empty, and upon adding some DOT 4 the pedal was a bit better but still low and I did not trust it. Car is not absued and clucth itself is not slipping under normal operation.
Does this sound like a clutch master cylinder, slave cylinder, or clutch wear itself? I have not yet had a chance to look for a leak, but will tonight after work.
Thanks!
Thanks!
Originally Posted by akirhol,Jun 22 2010, 09:00 AM
Did you do a proper bleed of the CMC fluid? If not, you should... I'm no expert by the standards of these forums, but I believe that simply adding fluid to an almost empty reservoir does not address the air that has likely already made it's way into your CMC. That would be step #1 I believe.
Thanks All. I will check the cylinder for a leak tonight - I assume it will be leaking into the cabin by the pedal and not onto the ground (have not seen anyhing on gargae floor).
I did not bleed the system this morning, but will once I replace the faulty part (with a mighty-vac). just glad it will not be too involved of a job.
Thanks!!
Rob
Thanks!!
Rob
Originally Posted by jeffbrig,Jun 22 2010, 09:07 AM
It also doesn't address the underlying problem. Where did your fluid go that caused air to be sucked in through the reservoir? Your 2004 is right about the typical age when the clutch MC seals start to go. Look for fluid where the plunger goes into the MC by the clutch pedal. You may be able to drive the car after you fill/bleed the system, but it's just a matter of time until it leaks out again. Or the seals fail completely (hopefully not while you're driving). Confirm the leak, then order the part ASAP.
Took out the clutch master cylinder last night and there was a lot of fluid/junk on the piston end of it, as well as a little leak onto the carpeting. I checked the slave cylinder and all tubing/fixtures and not a single drop of anything so I presume the CMC is the casue.
Will have a new OEM replacement tonight from Honda and should be back in business rather quickly after the bleeding.
Thanks!!
Thanks!!
Thanks!!
Thanks!!
