Clutch problem?
Old Mar 6, 2005 | 09:20 PM
WtbS2k's Avatar
Default Clutch problem?
Hi guys,
I found some black stuff leaking out of the clutch cylinder? while i was working on my car. is this normal? here is a picture.
Old Mar 7, 2005 | 03:18 AM
hondamanwill's Avatar
Looks like it is starting to go bad. Leaking past the seals. Keep an eye on it.
Old Mar 7, 2005 | 04:00 AM
Slows2k's Avatar
It's not starting to go bad, it has. You'll need a new clutch slave cylinder.
Old Mar 7, 2005 | 05:31 AM
cdelena's Avatar
That looks like the back side of the clutch master cylinder (driver
Old Mar 7, 2005 | 07:44 AM
rikhemi's Avatar
you probably need to replace it.. mines went out 2 months ago when the car was at 45k miles. my clutch stopped engaging, when i checked the fluid for the clutch, there was none, replaced it for 50 dollars.
Old Mar 7, 2005 | 01:32 PM
WtbS2k's Avatar
Thanks for the help guys.
I feel no difference when i drive it, what exactly will need to be replaced or i just need to keep an eye on it.
Old Mar 7, 2005 | 03:50 PM
revhi's Avatar
Your clutch master cylinder needs to be replaced. Do it as soon as possible. Mine went on my Prelude before like that to.
Old Mar 7, 2005 | 04:06 PM
Slows2k's Avatar
The leak has allready started, it's not going to get any better. It will continue to act normally untill all of the fluid has leaked out. Then you won't have a funtioning clutch.
Your profile shows you have an 03, It will be covered under warranty.
Old Mar 7, 2005 | 11:07 PM
WtbS2k's Avatar
Thanks guys! I will take it to the dealer as soon as i get it out of the storage (in about a month).
BTW, is this a really common problem? My car only has around 8000 miles on it.
Thanks again!
Old Mar 7, 2005 | 11:26 PM
RACER's Avatar
[QUOTE=cdelena,Mar 7 2005, 06:31 AM]That looks like the back side of the clutch master cylinder (driver
