Clutch Problem
Old Jul 18, 2009 | 10:17 AM
GpWaP1 s2k's Avatar
Default Clutch Problem
i did a little searching on here but could not quite find the answer to my question...i just installed a new comp clutch stage 2 kit and a resurfaced stock flywheel on my 01 S...i also replaced the stock flex line with a braided SS line...now heres the problem i bled the line but it seems that the pedal is real weak...weaker than a stock clutch...i can shifter through gears if the car is off but when it is on i cant shift into or out of any gears...ive bled the line about 5 or 6 times and it the pedal is still soft...i dont see any leaks coming from the slave cylinder or the MC...i checked and made sure that th clutch fork was in the release bearing and that the slave cylinder was in the clutch fork...when the clutch is pressed down the slave cylinder moves the clutch fork...does anybody know what might be the problem? do i need to adjust the clutch? somebody told me that i might need to pressure bleed the lines...has anybody ever had to do this on their S to get it to work?
drewc
Aug 8, 2015 01:07 PM
rickw06
Jan 2, 2014 10:52 PM
kenchow69
Feb 1, 2010 03:05 AM
s9k
Jun 3, 2009 11:16 AM
sanee515
Aug 23, 2004 01:51 PM
