clutch problem
Old Dec 18, 2010 | 03:35 PM
keefss2k's Avatar
Default clutch problem
i have ap1 with intake an exhaust an competition clutch 6puck ironman disc an when i crank up the car an let it idle it sounds like a spring is gettin slung around in there the car shifts fine when you put your on the clutch the noise is not as loud an you can feel like a metal on metal grind through the pedal could it be jus a spring? just lookin b4 for i tear it down an be a timely process an wanna make sure i get all the parts lmk if anyone had same problem or know what it could be , thanks
Old Dec 18, 2010 | 03:38 PM
rob-2's Avatar
Could your throw out bearing be going?
Old Dec 18, 2010 | 03:56 PM
keefss2k's Avatar
its prolly got maybe 8k miles on entire clutch when all new was installed. Could the throwout bearing be bouncing around in there? (is that possible an still shift fine ?) driving the car drives fine jus doesnt sound good lol what can cause the throwout bearing to go out?
Old Dec 19, 2010 | 01:52 PM
keefss2k's Avatar
anyone have any ideas?
Old Dec 19, 2010 | 02:35 PM
ronnuke's Avatar
Could be the pressure plate broke a finger...or the throwout bearing, it needs to be properly greased with super high temp urea grease on install or it will cause problems with shifting. Did you replace the throwout bearing at the last clutch changeout?
Old Dec 19, 2010 | 07:07 PM
keefss2k's Avatar
yea its a comp clutch ironman kit maybe 6k mile on entire kit also is a rattle in there somewhere when i let the clutch out feels like there something biting the pedal
oooBernard
Apr 17, 2013 11:59 PM
keefss2k
Dec 19, 2010 07:12 PM
silverf20
Aug 9, 2008 01:24 PM
StatixNWH
May 7, 2007 01:33 PM
supp64
Jul 3, 2006 05:55 AM
