clutch problem
Old Mar 1, 2012 | 04:27 PM
vasquezgno's Avatar
Default clutch problem
Ok so i wake up this afternoon since i work overnights to find out my car wont go into gear and the clutch has no play. I went t cocheck the fluid and it was empty which i would suspect a leak somwhere. Will i need to change the slave cylinder or master or is it as simple as bleeding the clutch? Wat am i looking at in parts and labor for this problem? can iadd fluid now and drive it to the shop or get it towed because i dont want to do more harm than what is already done. Would like answers soon for my car is my daily driver at the moment.
Old Mar 1, 2012 | 04:58 PM
speedjunky01's Avatar
you have a leak for sure fill and bleed, find where its leaking from, replace part
Old Mar 1, 2012 | 08:49 PM
s2krider88's Avatar
to replace cmc and slave its like a total of 3 hours including bleeding its very easy. look up in the diy it'll explain it all step by step very easy!
laserred02
Nov 28, 2012 07:12 PM
vasquezgno
Mar 3, 2012 08:19 AM
Spiny Norman
Jul 14, 2008 08:19 AM
Amit
Mar 21, 2006 07:54 PM
optical
Oct 9, 2002 04:50 AM
