clutch problems..help
Old Jul 28, 2004 | 06:19 PM
jsasoldier's Avatar
Smile clutch problems..help
hi guys..i own a 2002 model and it has about 35k on it. Lately the clutch has been very rough. I have went to the dealers couple of times and they said it just needs some lube and that was it but the roughness keeps coming back. It seems like guys at the dealer don't want to take a closer look. Maybe they want to charge me for the parts when my warranty runs out or something. anyways, please help.
Old Jul 28, 2004 | 09:00 PM
Rickjames's Avatar
I would check your clutch fluid. My clutch has a notchy feeling--and when I checked my clutch fluid, it looked like coffee grounds. The clutch fluid is just DOT 3 brake fluid, and if you are familiar with brake fluid, it turns a dark color when it goes bad. I need to change mine--will probably do this weekend.
Old Jul 28, 2004 | 10:02 PM
ThaWyze1's Avatar
When's the last time you changed clutch/tranny and diff fluids?
Old Jul 28, 2004 | 10:07 PM
ThaWyze1's Avatar
If you suspect it's something else, take it to a trusted mechanics shop and have them diagnose it. My AC compressor went out, but the dealership didn't really want to check it out, so they just said I was low on coolant, which it was full. So I took it somewhere else and they found out the real problem was the compressor. Don't trust dealers. They're too concerned with making money and getting cars in and out.
Old Jul 29, 2004 | 06:04 AM
xviper's Avatar
Please explain what you mean by this.
Old Jul 29, 2004 | 02:20 PM
jsasoldier's Avatar
thanx guys....
i have not change the fluid so i probably do that this weekend.
The clutch feels like it's scrapping something at engagement point.
very irritating feeling.
Old Jul 29, 2004 | 03:17 PM
xviper's Avatar
This could be a bad master cylinder, bad slave cylinder, poorly lubed release fork, a binding throw out bearing.
Old Jul 31, 2004 | 01:13 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I'll put in a second vote for poorly lubed release fork. You can drop the slave, partially pull the fork, and grease the pivot pin. Upon assembly, grease the ball end of the slave rod.
Old Jul 31, 2004 | 01:51 PM
RACER's Avatar
I think it is the muffler bearings
Xeon
Mar 6, 2021 03:27 AM
Henwee
Apr 10, 2015 06:25 AM
acn684
Aug 16, 2011 09:36 AM
hellspare
Jan 12, 2010 01:34 PM
LNKs2k
Jan 10, 2009 04:59 PM
