Bleeding Clutch / Clutch Fluid
Old Jan 8, 2009 | 04:16 PM
LNKs2k's Avatar
Banned
Default Bleeding Clutch / Clutch Fluid
Hello... I'm really dumb when it comes to car stuff..
All I know is that I have a s2000 that I love very much..
I have a couple questions.
1. Is Clutch Fluid and Transmission Fluid the same thing?
2. Tomorrow I'm having the Clutch Fluid flashed.. Does that also mean having the clutch bleed? Is that part of it?
How much should that normally cost me for both?
Thank You
Old Jan 8, 2009 | 04:19 PM
LNKs2k's Avatar
Banned
Also. How do I check the level of the clutch fluid?
Old Jan 8, 2009 | 04:30 PM
kial007's Avatar
Clutch fluid is brake fluid. Tranny fluid is completely different. If your clutch fluid is going to be flushed, they will have to bleed it.
To check the fluid, take the cap off of the smaller of the two resevoirs on the firewall, against the drivers side fender.
Old Jan 8, 2009 | 04:44 PM
mlc's Avatar
mlc
Here is a great write up on bleeding your clutch. Even if you dont do it yourself at least you know what they are doing to your car.
http://forums.s2kca.com/showthread.php?t=12154 .
You should try it. It is not hard to do at all. You will need another person to step on the clutch.
Good luck.
Kevin
Old Jan 8, 2009 | 04:47 PM
LNKs2k's Avatar
Banned
To me this looks low. What do you think?
Old Jan 8, 2009 | 04:51 PM
LNKs2k's Avatar
Banned
Thanks for the step by step guide.. It looks simple. What type of fluid is needed for the clutch?
Old Jan 8, 2009 | 05:19 PM
Infidel99's Avatar
DOT 3 brake fluid. Go buy a new bottle, old bottles "go bad" and should be thrown away (disposed of properly-for all the tree hugging Prieus owners).
Old Jan 9, 2009 | 09:30 AM
vincewchan's Avatar
That thing is near empty. Is it leaking?
Old Jan 9, 2009 | 10:14 AM
jyeung528's Avatar
no it doesn't look low, it looks friggin empty.
glad you're getting a flush.
Old Jan 9, 2009 | 10:43 AM
ahrmike's Avatar
it looks dirty as well.
flush it well! plus look for the leak..most likely on the clutch master cyl. check behind the clutch pedal for a slow leak...+ wipe it up cuz that thing is corrosive..itll eat off the paint in a matter of weeks..
