clutch question
Old Sep 13, 2006 | 01:11 PM
dtn's Avatar
dtn
Default clutch question
i tried to search through the forum to find similar symptoms but i got mixed results. just wondering if someone could help me decipher...
my clutch seems to be engaging further to the ground, i recall it engaging higher in the past and also being stiffer. i haven't experienced any slips and i'm definately not hard on my clutch. its my00 with just over 60k. i haven't had any issues so far.
i thought it was because the fluid was a tad low, but that wasn't it.
help?
Old Sep 13, 2006 | 01:45 PM
Gregg Lee's Avatar
help?
The obvious first thing to try is to bleed the system. Flush the fluid completely while you are at it.
A hydraulic line aneurism. Partial failure of the pressure plate diaphragm.
I haven't heard of either happening on an S2000.
Old Sep 13, 2006 | 09:00 PM
REVZ TO9's Avatar
Banned
I have the same problem. Is your clutch pedal loose too like mine? I was told my clutch hydraulic cylinder is leaking air/oil. Cylinder needs to be replaced.
Old Sep 14, 2006 | 11:56 PM
dtn's Avatar
dtn
its a bit loose. i'm not sure if its just me being overly paranoid, but i think i recall it engaging much higher.
Old Sep 15, 2006 | 07:38 AM
REVZ TO9's Avatar
Banned
have your master and slave cylinder checked in your clutch hydraulics
Karl_h
Apr 1, 2012 11:26 AM
watchdogd
May 18, 2011 10:47 PM
ChefJ
Jul 11, 2010 01:43 PM
ebchu
Oct 17, 2009 08:59 AM
msmokie
Oct 25, 2007 06:05 PM
