Clutch system lubrication-
Old Nov 11, 2008 | 04:58 PM
killerbee_vr6's Avatar
Default Clutch system lubrication-
Can I get the throwout bearing cap (#1) greased through the shift fork hole without dropping the transmission? I'd prefer to save four hours if possible. Thanks!
Old Nov 11, 2008 | 05:56 PM
Bricksnite's Avatar
I was wondering this also! Was planning to take my tranny off over thanksgiving weekend, but if this works that would be great. If not able to get a grease brush that far into there, i was planning to get a can of the white lithium grease in the pressurized can, or a bottle of motorcycle chain lube and spray it in there.
Old Nov 11, 2008 | 06:11 PM
cdelena's Avatar
No, access is only with the box out. The slide should only need lubrication when the clutch and TO bearing is replaced.
Old Nov 11, 2008 | 06:46 PM
Slows2k's Avatar
Can't cheat that one effectively.
Old Nov 12, 2008 | 04:53 AM
Conedodger's Avatar
No need to grease it until you change the clutch. I would not spray any lube in there. The last thing you want to do is get lube on your clutch.
Old Nov 12, 2008 | 08:26 AM
devilchrist's Avatar
I can't recall 100%.. but on my supra, throw out bearing was a sealed unit.. can't lube it. period.
I'm sure it's the same with most cars? it's sealed so that clutch dust can't get in i believe.
Old Nov 13, 2008 | 09:29 AM
SpitfireS's Avatar
Slows2k Posted on Nov 12 2008, 05:46 AM
This groove needs to be filled with high temp (urea) grease.
You can drop some grease behind the throwout with a wire and it will help for a bit.
You'll need to keep the clutch fork out of the way and I also detached a part of the slave's hard line (without disconnecting it) to get it out of the way completely.
Old Nov 13, 2008 | 04:02 PM
Bricksnite's Avatar
My clutch was replaced about 9k miles ago, including the TO bearing. The previous owner took it to a shop, and im guessing they did a crappy job greasing it, or didn't use high temp, because the pedal feedback sticks.
Its not the fork/spoon for sure, and its not the pedal because you can feel the lag if you let the pedal up fast. Its unpredictable sometimes because it will stick then 'pop' out.
Ive had this problem on a G20 infinity, where the shaft was dry/gummed up. I was hoping to avoid dropping the trans though!
Old Nov 13, 2008 | 11:04 PM
Opposite_Lock's Avatar
I'm in the same scenario as you. I thought I greased the inside of the TOB enough...but sure enough after 600 miles, I have the sticky pedal. I completely forgot to grease the bearing cap!
I'm going to try to see if I can grease it through the release fork hole this weekend. Will post results. I really don't feel like pulling the tranny again...
Old Nov 16, 2008 | 11:40 AM
With a lift, we did a complete clutch job in two and a half hours last night.
