clutch/wheelhop?
Old Jan 4, 2010 | 06:35 PM
fallen612's Avatar
Default clutch/wheelhop?
well i finally finished breaking in the clutch today. i have the act clutch, act flywheel, act pressure plate, and a SS clutch line. well i was driving around mostly just doing 45 mph pulls in second just for fun. i was at a light and nobody around so i figured id just go from first. i didnt launch it just went out normal then i hit it. rpms went up and i shifted at 9k and when i shifted to second, it felt like wheel hop, but the rpms didnt go up like the tires were spinning. i maby did it for a 2 seconds and then it caught and went like went to redline again. what im wondering is it wheelhop or maby the clutch catching and slipping then catching agian doing that a few times and it just feels like wheel hop?? i did it again in 3rd gear but jsut did it once. not at all like in second. almost like it chirped 3rd. but the same wheel hop feeling, but only hopping once. i shifted pretty hard. so what do you guys think?? thanks!!
Old Jan 5, 2010 | 12:49 PM
YELLOW JACKET's Avatar
Who did the install? might want to break that cluch in a little longer. just a sugestion.
Old Jan 5, 2010 | 02:21 PM
fallen612's Avatar
I got my buddy here to do it. he works at meinake so we had a lift to do it on. i broke it in for 500 miles, act recommended 300 so i broke it in extra time. so idk. it was about 40~45 degrees out so maby that had somethin to do with it??
Old Jan 5, 2010 | 09:04 PM
fallen612's Avatar
bump anyone else???
Old Jan 6, 2010 | 08:38 AM
fallen612's Avatar
well i went out today and tried a few things. i went out and i got on it and when i shifted from 1st to 2nd i jerked the wheel a little bit to see if it would go sideways a bit to see if it broke loose. it did get a little sideways but the wheels were keep hopping. so im still not 100% if its clutch or wheelhop.
another thing i noticed when i shifted and it started hopping the revs dropped and went up and down maby 250-500 rpm differnce for a few times. so that got me thinking it is wheel hop again.
so im 90% sure it is wheel hop. just trying to get a second opinion. any ideas???
Old Jan 6, 2010 | 08:49 AM
dales2000's Avatar
yea it sounds like wheelhop, which I hear is not good for the diff, i had the falken rt615s and they wheelhopped. I changed to the re01rs and no more wheelhop just a chirp lol
Old Jan 6, 2010 | 11:58 AM
fallen612's Avatar
hmm. im running Michelin pilot sports, the summer ones. is there any way of reducing wheelhop??
Old Jan 6, 2010 | 12:00 PM
dales2000's Avatar
im not sure i found my cure was a much better tire.
Old Jan 6, 2010 | 01:04 PM
TWM Performance's Avatar
Better tires, polyurethane bushings, stiffer spring rates, stiffer engine/tranny mounts are all things that can help to reduce/eliminate wheel hop.
Patrick
TWM Performance
Old Jan 6, 2010 | 01:06 PM
Soul Coughing's Avatar
check the tire pressure between sides. It happens to me when one tire has more traction than the other and an oscillation occurs. The technical reason it happens is mostly due to flex from the rubber bushings in the suspension components, but a lot of the problems can be helped or prevented by changing tire pressure and/or tires.
