Code #P0411 Need help.
Old Feb 6, 2012 | 07:34 PM
Rokar's Avatar
Default Code #P0411 Need help.
Well, as you can see the title says it all I'm looking around the internet for some answers and it all comes up with secondary air incorrect flow, now this is foreign to me lol, so if any of you gear heads out there what I need to go out and do to fix this problem I would greatly appreciate it.
Old Feb 7, 2012 | 07:34 AM
vufgew's Avatar
i had this problem for a long time and i have a k&n fpik the problem with mine was that when i initially installed it i had two vacuum hoses in the wrong spot. looking at other fpik installation photos i played around with the hoses until i got it right and reset the ecu and it been 6 months with no check engine light. do you have an intake? if you do then its probably the same hose problem i had.
Old Feb 7, 2012 | 09:12 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
vac line routing and white check valve direction must be exact. Check it.
Old Feb 7, 2012 | 09:53 PM
Rokar's Avatar
Thank you very much, you guys are awesome.
Old Feb 8, 2012 | 01:29 AM
INDYMAC's Avatar
Same thing happened to me when I changed the serpentine belt. I could have sworn I put the hoses back correctly, but I didn't!
Old Feb 8, 2012 | 04:21 AM
EagleDon's Avatar
I also learned the hard way.
After 2 wire tucks and relocating the secondary air reservoir and hoses under the L/F fender, I had used a vacuum hose connector to lengthen one of the vacuum hoses, which resulted in restricting the vacuum thus giving me the dreaded 0411 code after start-ups. After weeks of resetting the ECU and contemplating what was wrong, I decided to pull the fender again and reroute the hose with a new full length one to the IM and 'walla' it worked. NO CODE after start-up.
Lesson learned: Do not piece together any vacuum hose that may cause a restriction. Always use full lengths
Old Feb 8, 2012 | 04:26 AM
dwight's Avatar
voilà
Old Feb 14, 2012 | 02:24 PM
ThatSlowKid's Avatar
Spent the whole day today figuring out what's wrong. Nothing apparently, took the little cap off (saw it in another thread, and it worked for him). But did not work for me, gave me the CEL after 15 20 miles.
SO what did I do? Ordered Izzy's airpump simulator
Old Feb 14, 2012 | 03:30 PM
wait4vtec's Avatar
I've had this same check engine light but my hoses are in the correct order....any ideas of what else it could be?
LeafOnTheWind
Dec 3, 2012 04:17 PM
s2kcolin
Dec 16, 2009 09:23 PM
silvery2ks2k
Dec 23, 2008 06:31 AM
mrxwormxsayz
Dec 11, 2008 06:53 PM
JTran2000
Sep 19, 2005 09:09 PM
