Code P1367
Old Apr 22, 2014 | 07:15 AM
G2KS2K's Avatar
Default Code P1367
OK guys so i bought my S with this code, ive been a lurker for a long time and have read lots of threads, but since all that ive read i decided to post because my case is different in a BIG matter, i put the scanner and get code P1367 i know its for the TDC the weird part is the unlike everyone else that has this code... i can still rev up, past 3,000rpm. Reset the code still pops anyway, and i still can rev past 3,000... Anythoughts?
Thanks in advance guys
Old Apr 23, 2014 | 11:14 AM
G2KS2K's Avatar
Really, no one?
Old Apr 28, 2014 | 11:25 AM
G2KS2K's Avatar
Can ANYONE pitch in?
Old Apr 28, 2014 | 11:31 AM
MM3Kwolik's Avatar
Have you checked the sensors and their connections? Have you checked to make sure the vehicle is 100% in time? Are you stock running a stock ECU? There are so many details that you've left out that it'd all just be a big wild guess.
Old Apr 28, 2014 | 11:33 AM
06Estukay's Avatar
- Check sensor connections
- Try using a different sensor (borrow from a local S2000)
- Did you spill any fluids in the sensor area?
Old Apr 29, 2014 | 06:14 AM
G2KS2K's Avatar
Well my engine is 100% stock, mechanic told me that the plugs where broken and yes it did have fluids in that area, i currently have my engine out of the car (painting whole car) we will put engine back in today, already replaced the conectors and cleaned everything up, hopefully those code will be eliminated! Thanks for the help!
Old May 2, 2014 | 10:22 AM
G2KS2K's Avatar
Hey guys just to update you guys, problem was fixes by changing the plug for the sensor! code went away! and everything is ok now! So just like all the other post indicate, always check the conectors.
However never got around to see way i had the code, but was able to rev past 3K rpm. but dont care know, since my engine is ok now.
LightlySalted
Feb 19, 2019 09:28 AM
kw_21
May 28, 2014 07:06 AM
ipopvtec
Jul 2, 2012 06:27 PM
caleb2483
May 16, 2012 03:01 PM
RobEvo5
Nov 28, 2010 05:43 AM
