coilovers...
Old Jan 31, 2006 | 07:25 AM
ayS's Avatar
ayS
Default coilovers...
hi, i am having a hard time raising my car with my coilovers. i have megan racing track coilovers. i was thinking of trying to put some wd40 on them. would this be a good idea and would it work?
Old Jan 31, 2006 | 05:18 PM
Project SSAP1's Avatar
hhahaha...naw man..u just need to hit the gym to get some arm strength..lol..
n e way...WD-40 will help a great deal if the coilovers have been at a set height for a long period of time...
Old Jan 31, 2006 | 05:20 PM
ayS's Avatar
ayS
actually i had someone else help me out. and he still coulden't get the coils to go up.
Old Jan 31, 2006 | 05:32 PM
JAPCAB's Avatar
Banned
u need shit load of WD 40, let it really sink in. Then a wire brush that you can brush the threaded part of the coil over to try and remove some gunk that is stopping em from moving.
Now do you have the supplied 'c spanners' for your coilovers? if so, place them on the coilover nut and hit it with a hammer. If you dont have the c spanners, you can use a flathead screw driver, but be careful the metal on the coilover nut thingos can be soft like my old tein's and if you hit it hard enough you can snap a piece off. just use plenty of wd 40, wire brush it up and tap it.
Old Jan 31, 2006 | 05:41 PM
Bassem's Avatar
You are jacking your car up, right? It would help a lot if the perch is not preloaded by the car's corner weight. I know it sounds stupid but some people can access the shocks by turning the wheel.
Did you try turning them down first (like you are dropping the car)? It may be easier to "break" them loose that way and then go the other way.
Bassem
Old Jan 31, 2006 | 06:47 PM
ayS's Avatar
ayS
i will need to get my hands on a wire brush. maybe i'll just try and let some wd-40 soak and see how it goes from their.
Old Feb 1, 2006 | 09:31 AM
bighead's Avatar
I would try a penatrating solution before wd40... look into PB blaster.
Old Feb 1, 2006 | 02:13 PM
SlidinS2k's Avatar
Are your springs compressed? Relieve some pressure off the springs and try it again.
Old Feb 1, 2006 | 03:48 PM
ayS's Avatar
ayS
well they were once about stock height, so i know they can go higher if that's what you mean?
Old Feb 1, 2006 | 03:56 PM
jeggy's Avatar
what he means is, is there weight on the springs? are the wheels on the ground or off.
tomxt99
Sep 8, 2014 12:50 PM
s2k_cy
Συμπεριφορά
Feb 21, 2014 09:11 AM
Nottm_S2
Car Talk - Non S2000
Apr 1, 2013 04:39 AM
eskos2k20
Mar 20, 2013 08:29 PM
Kuba s2k
Aug 28, 2011 02:47 PM
