Cold weather and coolant.
Old Feb 26, 2024 | 09:29 AM
Slowcrash_101's Avatar
Originally Posted by windhund116
Most things expand with heat. Contract when cold.
Air largely follows that trend, air expands when hot, and its density decreases, and its viscosity increases, when air is cold it's density increases, it's viscosity decreases. Now air pressure affects the boiling point of water, so colder air being denser would exert more pressure on water, also the colder temperatures would be less prone to evaporation. As air pressure decreases(due to heat), it helps water evaporate as there's less pressure containing it, but as water evaporates it takes heat with it, so it becomes a self limiting system.
Old Feb 26, 2024 | 06:14 PM
Utah S2K's Avatar
Evaporation. The overflow tank is not sealed. When the radiator cap relieves, due to system fluid expansion, it dumps hot fluid/steam into the tube leading to the overflow tank. The tube goes thru the overflow tank cap where it is submerged (a vacuum system is created) in cooler fluid. The cooling system is “closed” because this vacuum. But the overflow tank is not “closed”. Each time hot fluid cycles through the overflow tank, the fluid in the tanks warms causing a small amount of fluid to evaporate through the cap.. It escapes at through the cap where the hose passes through. You can see white residue by the feed through on the outside of the tank cap.
Utah
Old Feb 26, 2024 | 10:31 PM
RolanTHUNDER's Avatar
An aside: What are the advantages of using silicone-based hoses over rubber types?
Thanks!
Because Spoon blue hoses
Those are made of a compound (ethylene, propylene rubber) so they're not silicone...?
Old Feb 27, 2024 | 06:51 AM
windhund116's Avatar
Those are made of a compound (ethylene, propylene rubber), so they're not silicone...?
So, Spoon hoses don't have the porosity of silicone hoses?
Thanks!
Old Feb 27, 2024 | 04:56 PM
jiepo's Avatar
Spoon hoses are advertised as SEP (Silicone Ethylene Propylene) rubber and rated for up to 160c compared to 120c stock EPDM.
Samco's are rated at 180c.
Can anyone confirm whether the Spoons permeate?
Old Feb 27, 2024 | 09:13 PM
Thanks!
That is a good question my friend!
On OEM hoses for the past 24 years now (MY 00 AP1) and they still look new so...if it ain't broke
Old Feb 27, 2024 | 09:18 PM
Thanks for clarifying what the S stands for.
Old Feb 28, 2024 | 05:53 AM
"Let sleeping dogs lie," has merit.
RQs2K
Jun 6, 2022 07:01 AM
Allday
Jan 8, 2014 03:23 PM
tozerman
Sep 25, 2013 07:15 AM
johnbuck
Jul 27, 2007 04:02 AM
evoman2669
Dec 7, 2005 05:12 PM
